Icon upper control arms
Old 01-24-2013, 03:19 AM
ARB1977's Avatar
Are these hard to install? Nothing needs to be pressed in the spindle? I'm debating on getting these vs other brands?
Old 01-24-2013, 11:44 AM
turbo8's Avatar
They are not too hard to install, you will have to press out the upper ball joint from the spindle and press in the adapter slug into the spindle.
you will have to move some stuff around the engine bay to get the upper arm bolts out.
Old 01-24-2013, 12:55 PM
ARB1977's Avatar
Thanks. Are there any tricks other than a press to remove and install the slug?
Old 01-25-2013, 11:46 AM
turbo8's Avatar
I used a modified pitman arm puller to press out the ball joint and to press in the slug.
Old 01-25-2013, 12:44 PM
ARB1977's Avatar
How did you modify the pitman arm puller to work?
Old 01-25-2013, 02:51 PM
turbo8's Avatar
ground it down some, bought it from autozone.
Old 01-25-2013, 03:51 PM
ARB1977's Avatar
Thanks.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
aowRS
09-13-2017 08:22 AM
pickle6415
12-25-2015 07:34 PM
potatopants
09-15-2015 06:26 AM
justdifferentials
09-05-2015 06:52 PM
Quick Reply: Icon upper control arms
