I want my own wheel thread!
I was starting a search to help me with my wheel backspacking questions and there are so many active threads that I thought, "I've just got to have one of my own!". So anyway, what's the stock backspacing for a 97 taco (I'm unsure what gen 4runner that translates to), and if I go from the stock 15x7 wheel up to a 15x8, should I maintain the stock backspacing or change it? And if I should change it, how much, just 1/2 of an inch?
BTW, in the short term I would probably mount my 31.5x10.5tires, with semi long term goal (a month or two) of going to 32.5x11.5 (which I know you can run on 15x7's, since bajataco does it, but I just want some new wheels I figure I should grab the little bit of extra width while i'm at it)
stank you,
Ian
stank you,
Ian
Follow up question...
If I go from alloy wheels (stock) to steel wheels, Will I need to change my tire rotation pattern to work in my spare? I ask, because if I do, then I will buy a five wheels instead if four to keep things cool and the gang.
A 15x8 wheel with 4.25-4.50 backspacing would likely be ideal. That's seems to be the most popular number with us "16'ers". If you want to run a 5 tire rotation I'd say yes, get 5 wheels and 5 tires. If not, just get 4 and rotate them normally.
So 15x8 black rockcrawler series 97's are on the way. I'll be sure and post pics when they get on.
Is it me, or does 4wheelparts kinda' suck?
Originally Posted by ianshoots
*snip*
Anywho, I cancelled my order. Puts two hundered odd bucks back in checking and leaves me to think about painting my stock alloys for now....
Live and learn.
06-01-2021 01:51 PM
terminator
07-27-2015 07:13 PM
skoti89
07-06-2015 07:45 PM
