I may have F'd up my deckplate mod
Okay here is the situation. I used a low oder/fumes silcone that I found a Home Depot. I could not find any sensor safe silicone anywhere, I even called automotive shops, no one had any. So I went with the best that I could. I let the stuff dry as much as I could before I put everthing back together. But I'm still really worried about havinf F'd up my MAF sensor. Can anyone tell me what they think about my situation. I really want to know what others thing could possibley happen.
It's not a matter of what I want to do anymore, it's a matter of what I already did and now I'm worried, shoulda grilled some more shops b4 giving up so early. Anyone else think I F'd up big time or if I might pull out okay.
How will I know if I did my MAF in, and that I will need to replace it?
I personally didn't do a deckplate mod on my 4Runner (1991) I've read that it's not possible to anyway, but I don't understand why not, I mean you could probably punch a hole in the top of the airbox (Might not work, haven't looked at my old box since I installed my FIPK Kit). I myself would of kept trying to track down the sensor safe silicon stuff, or talked to a few different places and seen what they think and suggested. But since it's already said and done, I'm sorry to say it but only time will tell. I'd say that if your MAF sensor doesn't break or stop working, then you lucked out
-Braden
-Braden
Stump,
I think that you should do what you can to remove the deckplate and get all of that silicon off. It will ruin your MAF sensor. It may take a day or a month, but it will happen. Do a search on both forums and you will find some threads talking about it. BTW, I got my sensor safe silicon at Autozone for like $3.00 Hope it works out for you. Later.
Matt
Matt
Stump:
I agree w/ LSU. Why take the risk?
What I did was to take a flat piece of rubber from the hardware store, cut out a ring, and just simply screw the deck plate over the rubber ring. No worrying about fumes or anything.
I sent Dbui a piece of it too. Did you use it yet, Dave? If you don't plan to, send it to Stump!
Bob
Bob
Senior Member
I'm not trying to start a war here, as there are certainly some people on this board that know a whole heck of a lot more than I do, but...
Has anyone ever seen damage cause to the MAF from non-sensor safe silicone? Not just coincidental problems, but actual damage directly caused by using non-sensor safe silicone? I haven't. I did my deckplate over a year ago, before I had ever heard anyone talk about sensor safe and non-sensor safe sealants. I used silicone that I picked up a wall-mart. Doubt it was sensor safe since I wasn't looking specifically for sensor safe silicone. I haven't had any problems.
As far as your options... seems like you can leave it as is and see what happens, or you can pull your air box out and cut the deckplate out, thus having a hole in your airbox that you can't seal (I don't think you could remove the deckplate, all the silicone, and redo the mod using sensor-safe sealant). I'd be more inclined to go with the first option.
Just my $.02... take it for what it's worth.
Stump,
If you end up getting it via the web, let me know where you get it from. I just ordered my Amsoil air filter (via Gadget's Amsoil ref) and will be doing my deckplate mod shortly after.
Here are a few other questions.
1. Does anybody know a site that sells the actual deckplates? I have heard a few people talking about going to boat supply stores, but I really don't know of any near me. It would be just as easy for me to order it online if somebody knows where I can get it from.
2. I thought I heard somebody say that they had a big enough drill bit or some sort of 4" hole bit for their drill. Was this correct? If you do, where can I find them? Home Depot?
I know that I can dig through tons of old posts, I just figured that it would be easy to ask here (feeling a little lazy right now).
Thanks!
Thanks!
JACKSON and STUMP: heres a thread you wanna look at...
http://www.outdoorwire.com/cgi-bin/u...;f=13;t=008969
I would be hapy to take the deck plate off and re-do it using the right stuff, but there is no way I can. My Runner is my only car, and I have class everyday and work right after that, Today, Wed, and Thurs., then my baby goes in bright and early to get it's lift installed. I really can't find any time to re-do this job. About the only way I can think would be to skip one of my classes and take the few hours I have there to rip it off and re-do it all. I can't do anything about that though until at least Thurs(I have one class that I don't NEED to be in). so that means today and tomarrow running w/ this thing in. Will the damage already have been delt to my MAF after those few days, or is this a good idea to try and do it as soon as I can?
Just leave it on there. Worse case, you will need to replace the sensor if it goes bad. I am sure that you could find one at a junk yard or something if you had to.
I would remove the deck plate, get as much sealant off that you can and reinstall your air box and filter, order the silicone free stuff and finish the deck plate when it arrives. just dont go driving through deep water or heavy dust. and keep your fingers crossed!!
Originally posted by cybrenergy
Stump,
Thanks!
Stump,
Thanks!
http://store.yahoo.com/rodi/per82180.html
AutoBarn.com for the Sensor Safe Sealeant
Get a 4.25" hole saw for your drill and that hole will only take a few seconds to make and come out real clean.
Honestly, from what I have read on here and the other board that (outdoor wire), it really seems that more people have NOT had problems with it than have. It also seems like most people did not use the sensor safe silicone. It really seems that chances are you are not going to have a problem.
seems like to me, most people DO use the silicon safe sealant. why not, i cant hurt. but the non-sensor-safe silicon HAS been known to damage the MAF and/or O2 sensor. you pick, new MAF and O2 or re-do deckplate.
Originally posted by jalaber
www.westmarine.com for the deckplate
Thanks for posting the links!
