i finally did my HID retro but i ran into a problem, Plz help lol *PICS*
for those that have done a bi-xenon projector retrofit, how did u wire up the high beam solenoid? ive tried the ways that were posted on HIDplanet, but no luck.
right now:
- the low beam turns off when the high is engaged.
what i need to achieve:
-have the low beam stay on while the high beam is activated
-find a working wire diagram
any help will be much apreciated, thanks and enjoy the pics!
Always make sure your headlamps are lying down on its back or has some type of protection. i stood it up and it managed to tip over on its own. such a waste...
right now:
they are switched ground IIRC, so a harness with some relays wouldbe your best bet. ill dig for the diagram that i had saved. im going with single xenon low beams and infiniti qx4 highbeam projectors. but the diagram should work.
That seems like a pretty clean install ...can you post some pics of the back of the headlamp and how you secured it headlight?...Are you using the E55 Bi-Xenon projectors?
thanks guys, i stoped taking pics of the process as it got messy. ill post more pics of the back tho, and of course the beam pattern. i have to play with the camera a bit more. yes im using the e55 bi-xenons off ebay.
i wanted an ome look. so i mounted the projectors further back, but there are clearance problems by doing this.
-can't use the stock airbox
- battery must be moved aside, relocated, or slimer battery is needed.
again, ill try to post more pics, i also have to THANK all those who have posted pics of their retros and information which have encouraged me to finish the project. because of the clearance problems i almost gave up...
heres a beam pattern pic right after i installed it without proper alignment, i only aligned the beams to the same level, my driveway is also at an incline, so its not a good alignment point.
Nice.. I don't understand "leaving the low/high beam on" at the same time. The premise behind BI-Xenon is that there is a constant light output, then when the high beam is activated a small reflector allows light to travel more out of the projector giving a brighter/wider pattern. There is no high and low beam in terms of power output or light level, it's all about the reflector. I've heard that on BMWs Xenon systems you can actually change how the reflectors operate when on high/low and therefore change how light is displayed outside the projectors.
I ran mines using two relays, a positive switched realy for the low beam powering the HID at all times when you turn on your headlights and a negative switched realy for the high beam actuators....thus letting you have your HID on when you high beam but the downside of this is that because there is no feedback to the other wire on the main harness it won't trigger your high beam indicator light....but since your using the E55 I'm pretty sure you'll know when you got your highs on or not.
Here is my diagram...I never went back to fix the high beam indicator.
confusing ?
thanks
i think people still retrofit even with a lens like the 2nd gen. Especially beacuse they also cant find any clear lenses. it is still a great output of light. another good thing is it could hide the "eye ball" look a bit. are they glass? plastic lenses can be sanded down and made clear, but not glass lenses
heres a camry that did it
pics are from http://faqlight.carpassion.info/
That looks really good, I have been wanting to do this forever but I am not keen on opening the light with the oven and all that. So a couple of questions......
1. Where and what did you get for projector, ballasts, etc..... and how much?
2. Where did you put the ballasts?
3. Where did you relocate the airbox and battery?
4. What did you use to mount the projector to the light, JB Weld or something?
Thanks again....B
Thanks again....B
Thanks again....B
Thanks again....B
1. Ebay:
-aftermarket 99+ headlights 250
-Lexus is300 ballasts + bulbs 200
-e55 Bi-xenon projectors 120
Home Depot:
-JB kwik about 3-4 packages
-Aluminum sheet metal
-sand paper
-3inch hole saw and necesary hardware
Walmart or old bike
-Bike tubing
2. the ballasts are just sitting flat held in placve by Zip ties
3. i shifted the battery to the side, soon i plan to either make a new battery bracket, or do a twin slim battery setup placing one battery in the rear of the truck. for the airbox, i made an intake, not good if u wanna keep the airbox for wheeling
4. with the hole i made, the projector fits very snug, i just added jb weld to secure it in place.
also, i did not have to open or bake the light. my hands were small enough to fit through the hole to dry the inside after washing it out.
pics of the back as requested....
so do u still think the look is worth all the extra work????
