| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Hub noise
#2 (permalink) |
add should not really make noise. Allthe hub is, is a plate that fits over the axle shaft and bolts on. More than likely something else is making the noise. (controls arms , cv shaft, ball joints, anything front suspension)
__________________
~ Those who hesitate are not only lost, but miles from the next exit! ~ 1990 4Runner SR5, 3.0L V6, 5-Spd. ~ 3" BL ~ OME 900 ~ 32x1150 Dueler AT's ~ Magnaflow Cat-Back ~ Optima ~ Manual Hub Conversion ~ FLX-165 ~ Hella 530s ~ ISR |
#3 (permalink) | |
Quote:
__________________
mike '89 4Runner DLX: 2" OME rear springs, 1 5/8" RB BJ spacers, Diff Drop, 32" MT/R. '90 4Runner SR5: Stock Suspension, 32" MT/R . '07 4Runner SR5: 2" OME Rear Springs, Donahoe Coil Overs, Total Chaos UCA, 275/70-17 MT/R. '76 Jeep CJ-5: 4" Lift, 33" BFG MT. '87 Saab 900S: All stock '99 Subaru Legacy GT: All stock Last edited by mike_d; 03-02-2004 at 03:35 PM. |
#4 (permalink) |
same here..........only happens when its real cold.
i just figured it was caused by what mike d said above.
__________________
2004 Tacoma SR5 D-Cab 4x4 3.4L Auto 2001 4Runner SR5 4x4 3.4L 4-Auto |
#5 (permalink) |
same problem hear it is the outer c.v.joint when you drive it the grease heats up and when you park for the night the grease sinks to the bottom of the boot and then thickins up when you go out to it drive it there is no grease at the top so thats what you hear buy manual hubs save gas
#6 (permalink) | |
hub noise
Quote:
__________________
http://members.cardomain.com./jedi87 Old Toys 87 4runner 94 truck 914runner 99 4runner 95 Tacoma New Toy Stage 3 02 Audi S4 |
#7 (permalink) |
Hub noise
Well, I found out what was making the noise,It's the spindle.It was a $90 job at the dealer.They just regreased it and the noise stopped.The guy said 90% of the time you truck makes that noise then that's what it is.
__________________
#8 (permalink) | |
Quote:
#9 (permalink) |
Mine makes that noise as well. It started happening after I got into an accident and my left control arm, brake caliper, sway bar link, and rotor broke. I had those replaced. The 4wd drive works, but after I take it out of 4wd, it makes that noise for a few days and then it goes away. It does it mainly in speeds under 50mph. I always wondered what it was and it's funny that you mention the spindle because when my mechanic was changing the front brakes he mentioned that the spindle looked bent. I thought it looked a little off as well. Could this cause the problem? Any other suggestions.
__________________
98 4Runner SR5 V6 4WD, stock with a lot of dreams for my Runner. So much to do, so little money............ Oh yeah, the elbow mod. I live in NYC. With all the bumps and potholes, I don't have to go off-roading. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| hub to hub front ifs with 4inch super lift | jakindle | The Classifieds GraveYard | 2 | 06-09-2007 11:33 PM |
| Front right wheel howling noise in 2wd w/ locked hub | colsoncj | 86-95 Trucks & 4Runners | 3 | 02-13-2006 05:23 PM |
| Hub noise (nasty!) | lftd_86_yota | 86-95 Trucks & 4Runners | 2 | 01-26-2006 04:08 PM |
| hub/rattle/noise/annoying | Swissdrums | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 09-12-2005 08:15 AM |
| Front end noise in Cold - Manual Hub Fix | flyAddict | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 01-19-2005 09:08 AM |
