YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 02-16-2009, 08:24 AM   #1 (permalink)
Personal Sales Rating: (0)
How to test Igniter module?
Help!!! I have a '97 4runner 4x4 v6 and I think the igniter module has gone bad.
It all started when the check engine light came on. The OBDII code is P1300 (Ignition circuit No. 1)
I've replaced the spark plugs, wires, and tested the ignition coils to the recommended resistance specs.
Now, I suspect that the igniter has crapped out but am hesitant to replace it because the cheapest I've found was $336.00 I don't want to replace it unless I know for sure mine is bad. All the autoparts stores in my area is unable to test it for me. Like the ignition coil, is there any way to test the igniter? If so, what pins do I test? and what ohms?
Thanks for everyone's help
__________________
My Ride:
1997 4runner 132k miles
1999 M3 Coupe 42k miles
wanhp225 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 01-27-2010, 04:28 PM   #2 (permalink)
buckz6319's Avatar
this is something I came across...I used it and it...
Symptom: No Start.
Theory: The Ignition system on this engine uses a Distributor with three
Pick-up Coils inside and an external Igniter and Coil. The ECM uses the
signals generated by the three Pick-ups to control the Igniter, which
controls the negative side of the Coil for spark. The Igniter also sends a
signal back to the ECM for injector pulse.
The Test: The first place to start is to check the Pick-ups inside the
Distributor. If any of them are defective, nothing else is going to work,
not even the tap-test we're going to do later. The first step is to test
resistance on each of the three Pick-ups. You'll want to check them with
the harness unplugged from the Distributor. Identify the terminals on the
Distributor connector using the wire colors on the harness side.
Terminal-1: White..NE signal
Terminal-2: Red..G1 signal
Terminal-3: Black..G2 signal
Terminal-4: Green..G- signal
Between G- and G1, it should be 125 & 200 ohms. Between G- and G2, it
should also be 125 to 200 ohms. Between G- and NE, it should 155 to 250
ohms. All of these resistance specs are at ambient temperature. If checked
on a hot engine, the tolerances go up about 30 ohms. If any one Pick-up
fails the test, it needs to be replaced before any further testing. If all
three Pick-ups pass, we need to do a "tap-test" at the Igniter. Make sure
the connector is plugged back in at the Distributor. Go to the Igniter,
which should be mounted at the Coil. On the Igniter connector, locate the
Black/Blue wire and probe into it with a test-light. With the key on, tap
the alligator clip of the test-light on battery negative and watch for
spark out of the Coil. If you get no response, try tapping the alligator
clip on battery positive, again watching for spark out of the Coil. If
there's no spark in either case, check for battery voltage at the positive
side of the Coil. If that's okay, attach a second test-light from ground to
the negative side of the Coil and redo the tap-test at the Igniter. If the
test-light on Coil negative flashes during the tap-test, and you had
voltage on the positive side, you have a bad Coil. If the second test-light
did not flash on Coil negative, we need to check the remaining wires at the
Igniter. Make sure you have battery voltage on the Black/Red wire at the
Igniter with the key on. If that's okay, make sure you have continuity on
the Black/White wire between the Igniter connector and the negative side of
the Coil. Make sure the Igniter itself is grounded properly to its mounting
surface on the truck, no rust or corrosion. The last check will be to make
sure the Black wire does not show full continuity to ground. This wire goes
to the Tachometer, and if grounded somewhere in the harness, will keep the
Igniter from working. If all of these things pass inspection, chances are
good you have a defective Igniter. Be sure you check resistance on the Coil
to be sure we don't damage a new Igniter. The primary side should be 0.4 to
0.6 ohms. Secondary should be 10,200 to 13,800 ohms.
The Fix: Replace the defective parts determined by the above testing. Don't
forget, if you do end up replacing the Igniter, double check Coil
resistance to avoid damaging a new Igniter.
buckz6319 is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
88, 94, bad, car, coil, electrical, gm, ignater, igniter, ignition, module, spark, test, testing, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Hot Start Problem - How to test Igniter ? ColoradoRyan 86-95 Trucks & 4Runners 6 09-22-2008 02:05 AM
coil/igniter- test help needed pete f 86-95 Trucks & 4Runners 16 12-12-2007 11:02 AM
GM igniter 16.96 for Toyota igniter 457$ WORKS Paul R. Haller 84-85 Trucks & 4Runners 4 08-27-2007 11:41 AM
April Car&Driver test the new FJ cruiser in a comparo test X-AWDriver FJ Cruiser 24 03-05-2006 07:38 AM
Igniter callmej75 95.5-2004 Tacomas & 96-2002 4Runners 4 03-09-2005 11:31 AM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
