How to replace the 3rd gen Limited fender flare cushion
Old 10-23-2015, 06:33 PM
KZN185W's Avatar
Hi,
the cushion strips between the fender flares and the body panel have started to disintegrate in my truck. Can the cushions strips be removed and replaced without removing the flares?
If i do need to remove the flares, how do i go about it?
Thanks!
Old 10-24-2015, 12:49 PM
Nervo19's Avatar
I wasn't sure what you meant at first. You mean the gasket between the flares and the body? When I had an old Bug it was called fender welting or fender bead.
You have to remove the flare. I'm interested if anyone has a part number for them. This post shows how to do it and he ended up using 3M trim tape on the edges:
http://www.toyota-4runner.org/3rd-ge...e-install.html
Old 10-25-2015, 02:24 AM
KZN185W's Avatar
thanks for the reply.
I'll post the part numbers when I get them. but the part numbers for the cushion strips are color-specific.
will also need to order the clips.
95YOT
Colorado
05-17-2017 08:38 AM
Jgloade
11-03-2015 04:30 PM
voiddweller
10-22-2015 12:39 PM
shisha1999
10-21-2015 02:14 PM
Obmi
10-20-2015 05:22 AM
Quick Reply: How to replace the 3rd gen Limited fender flare cushion
