How loud is your Super Charger?
Old 10-05-2009, 06:54 PM
  #41
rimpainter.com's Avatar
Originally Posted by nuke1105
what is closed loop? Im no expert but i hear it alot. When the super charger is in closed loop does that mean that its in boost mode?
It's not the SC'r, it's the ECU (well, it's the system).
Open Loop: A set mode. The system does not compensate for external influences. In other words, your piggyback will take over.
Closed Loop: Dynamic; attempts to keep "error" to a minimum. We SC'd guys don't like this mode because the system is constantly trying to "fight" the mods we install to curtail the HG/LR ping problem. Retarding timing force-fixes this, but it's really a bandaid. So even though I can eliminate HG/LR ping, I have retarded the timing so much that my power increase from the SC'r is down to 50% at low RPM's and less than 80% throttle position.
I think I got that right. Sometimes I get them backwards...
Old 10-06-2009, 09:04 AM
  #42
Bennito's Avatar
Originally Posted by LarsDennert
I wonder how many people are running a smaller pully? Seems that would cause quite a bit of detonation. .
Myself and two others ran the smaller SCpulleys in Colorado (base elevation was 6k). no pinging. When I moved down to AZ, I had to pull the pulley due to pinging.
YMMV.
Old 10-07-2009, 03:08 PM
  #43
mastacox's Avatar
I'm running a 2.2" pulley, but I have a URD kit and have retarded the timing to get rid of any spark knock.
Old 10-07-2009, 03:27 PM
  #44
LarsDennert's Avatar
YMMV.
Pull the pulley? You mean go back to the 3.4 or whatever the standard one is? Meaning your pinging went away?
I'm just wondering if people are complaining but don't have a stock SC setup. How many people have the the standard pulley with no 7th injector and are getting acceptable performance. IE no ping or lean?
LOL the Runner is my wife's daily driver. She's complaining that it's too fast. Well not really but she likes it.
Old 10-07-2009, 04:11 PM
  #45
nuke1105's Avatar
I don't really understand your question but.......I have a supercharger with the stock pulley and no 7th injector and I think I get good performance. But I do get spark knock when go uphill or going up hill with a trailer. Other thn that it does not knock and works great. My truck now has 128k miles and I'm going to be adding the 7th injecor along with getting the sc rebuilt
Old 10-07-2009, 04:26 PM
  #46
slacker's Avatar
dont know if this will help or not ? (from MY Trekker build )
Old 10-07-2009, 04:43 PM
  #47
Bennito's Avatar
TWo step process. 1st step was to return to the stock pulley. Still got ping. 2nd step I installed the URD kit and detuned the lower end of the RPM map.
If I try I can still get some ping, but for nearly all driving its gone. I would suggest for most people not living at altitude, my experience is typical. YMMV
Old 10-16-2009, 07:27 PM
  #48
nuke1105's Avatar
No more spark knock!!!!
Solution : I pulled the stupid TRD SuperCharger off of my truck today!!
Old 10-22-2009, 08:05 PM
  #49
s/c_teacher's Avatar
just rebuilt my sc. thought a bearing was going bad. when i pulled the belt i noticed the pulley was loss. wabbling on shaft. the id on the pulley was wore. also the shaft on the nose unit was wore. this was causing a horrible noise. i'm a machinist and after getting some expensive quotes i decided to rebuild the unit myself. bearings, seal, oil. even replaced needle bearings in housing. not that tough if the rotors and bores are in good shape. be sure to use a good seal.
punks_is_4x4
02-26-2016 04:29 PM
smilen724
13
11-08-2015 04:11 PM
Davebarbier
11-03-2015 03:28 PM
Chicken12
10-14-2015 03:54 PM
JPV
09-28-2015 03:15 PM
Quick Reply: How loud is your Super Charger?
