| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
How to get at top rear shock bolts
__________________
2001 2wd 4runner Limited 5VZ-FE V6 auto Thundercloud Metallic ISR+Deckplate-Done! |
#2 (permalink) |
when i helped a friend put the lift on my 4runner it was a challenge. we had it up on a lift too and we still had to be contortionists to get in there. it wasn't bad just to get my hand on it, but fitting a socket and ratchet in there and then having the leverage to crank it off after 10 years in iowa was the big challenge. also, i had about an inch or more of dirt and sand that had to be cleaned out of the little cup area before i even got to the nut holding the shock on. i can't give you specifics about how to do it, but it does involve some twisting and maybe some odd yoga poses
__________________
The PATYWGN: 1998 4Runner Desert Dune Pearl. PATYWGN show-off thread Sport Hood FAQ |
#4 (permalink) |
Use a sawzall and cut right through the top stud of the shock at the rubber bushing.
You'll have them both done in about 30 seconds per side.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#5 (permalink) |
crap, I dont have a sawzall
__________________
#6 (permalink) |
Buy one, you'll use it again. They come in handy.
__________________
2002 4runner sport 4X4 87,000 and counting 2007 Camry LE "I'm bitterly clinging to Guns and Religion" (and I'll keep the rest of the constitution too) |
#7 (permalink) |
__________________
#8 (permalink) |
If you don't go that route, you can just put the socket up on there, then use a pipe wrench or something similar, and turn the shock body itself, as the socket/ratchet will wedge and hit the body/frame and thats all you need to do. Don't bother trying to turn the rachet itself, it will be too hard.
__________________
1996 4x4 3.4L 4Runner on 35's - 6" of lift, MTR's, E-locked, ARB Tacoma Bumper, Sliders and a cut off tail pipe. 1966 FJ40 - SOA with stock springs, stock 1F motor, and a smelly tailpipe. |
#9 (permalink) |
sawzall.
I had like a 7 foot 300lb mechanic put new shocks in for me. I wondered how he was gonna put his ginormous mitts in there. he just cut them off and new shocks went in fine with a ratchet and holding the shaft of the shock |
#10 (permalink) |
I ended up using a sawzal on mine.
I read tons of posts on how to get those rear shocks off. I tried everything that normally works: PBblaster soaking for days, torch, hammer, strap wrench, vise grips. On one shock I had everything starting to work & then the top bolt rounded. That was the last straw! I borrowed my friend's sawzall & bought a metal blade. They were off shortly after that. Good luck!
__________________
98 4Runner SR5 4WD, Desert Dune Revos, Custom mounted Hella 550s, Yakima Rack 99 Corolla, 38mpg. |
#11 (permalink) |
Cut the chrome rod as close to the top as possible - it holds fluid lower down. If you cut where the fluid reservoir is, you'll get doused with shock oil. I don't have a sawzall either, I used a high speed angle grinder with a cutoff wheel.
__________________
Jon 97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets |
#12 (permalink) |
I guess the general consensus is to cut them off. By the way what are the torque specs for the top and bottom bolts, the all the online manuals I can find are all for tacomas and are hence useless.
__________________
#13 (permalink) |
I'm having this very problem right now....only thing is I can't use a sawzall at the top because my flares get in the way....gonna take it to a shop tomorrow with air tools and get them to cut it off. I've tried everything else too including heating it up with a torch and using wax to break the bond the rust has. No dice.
bottom bolt is 47 not sure about top edit: Did you guys have to bend the sawzall blade to get it snug up to the top? Will the blade take that safely? Last edited by Mason Dixon; 03-02-2008 at 07:20 PM. |
#14 (permalink) |
I don't understand why your flares get in the way, you need to take out the spare tire and sit underneath to cut them out. I used a 9" Milwaukee torch metal cutting blade on the sawzall and yes, it did bend a bit but no problems cutting them off.
__________________
#15 (permalink) |
easy way
just install a body lift, then it is easy to replace...just hold bolt from outside of frame(by tire) since now there is a gap between body and frame...
__________________
1997 4Runner Alot of mods will list later date More pics just visit myspace link http://www.myspace.com/4runnerlover |
#16 (permalink) | ||
I tried screwing around with a wrench/pliers etc for hours. Eventually I gave up, bought a $20 angle grinder and cut the shock shaft. Then started slicing it away bit by bit until it pulled out the top. You must slice from the bottom because there are brake lines above the shock mount.
__________________
1990 Toyota 4Runner 22RE 5spd *Aussie Locker*York OBA* Quote:
Quote:
More info on 4Runners |
#17 (permalink) |
Top shock nut torque specs for 3rd gen 4Runners: 14ft/lbs or 168in/lbs according to the FSM/Hanes manual.
Just about had it with my rear shock nuts too. Looking into the strap wrench/vise grips/cut-off methods at getting this POS off. PB blaster might need a little more help. And good grief, the access design is just bull. Not sure if torquing that top nut is actually possible less a smaller 1/4 drive torque wrench was available.
__________________
2000 4Runner V-6 3.4L FI 5VZ-FE, 5-spd manual, NGK plugs/wires, Amsoil: filter/engine oil 5w-30, tranmission/transfer case 75w-90 GL-4, rear diff 80w-90 GL-5, front 75w-90 GL-5, Trekmasters/OME 890 in the rear, Centric disc rotors w/ Hawk LTS pads, slowly upgrading seized, stripped or broken, impossible access to hard-to-reach places, discovering I don't have the tool/part needed to finish the job, in the middle of the job....PRICELESS & worth it all once achieved! Last edited by 75w90mantraN; 07-06-2008 at 04:53 AM. |
#18 (permalink) | |
Quote:
As for torquing the nuts, just hand tight using a small socket wrench with a deep socket... I tried hand tightening with a torque wrench on another nut, and found what 14 pounds should be, then applied similar force to the crown nut. Not scientific, but hey, it worked. I have since put 10k miles on them with no problems.
__________________
1998 5spd V6 4Runner SR5 OME 881/890 4Crawler diff drop Tokico trekkmasters WabFab quick disconnects LC wheels Goodyear Wrangler Silent Armor ATs (285/75/16) |
#19 (permalink) |
What i did was put a socket up there and held the shock with some dykes, it tore the crap out of the old shocks, but it got them off.
I second just sawing them off, its the easiest way, since they are gonna get ruined period.
__________________
97 4runner, 2.7 5speed 4wd, 5.29, 33 horns armor locked lifted heavy SOB broken front and rear swaybars My Profile.. |
#20 (permalink) |
Sawing off the old shock is good and all. But how do you tighten the new one if there was no way to get the wrench in there in the fist place?
__________________
'99 4WD 3.4L SR5 AT |
#21 (permalink) | |
Quote:
You can do what i did, so you can run normal eye and eye shocks. ![]()
__________________
#22 (permalink) | |
Quote:
By the way, your rear sway is going to fall off
__________________
#23 (permalink) | |
Quote:
I squeezed the heck out of the upper shock with a big channel lock and then used a ratchet with socket from the fender well. I think it was a deep socket I used and the ratchet fits perfect just above the frame. I was going to pass this along to you folks who are considering a body lift in conjunction with a suspension lift. Do the body lift first, this makes replacing the rear shocks much easier! Have a good week! Brian
__________________
Brian 1998 4runner SR5, 3.4, auto, 4WD, OME 881 springs front with toytec spacers, OME 890 springs rear, WabFab 1" body lift, 285/75/16 Super Swampers, Rola roof rack, Deckplate mod..... |
#24 (permalink) | ||
I have no body lift, and I think it took me all of 1/2 hour to get these shocks out, I cant remember exactly what I did, but I did not cut anything. There should be enough room, if you cant cut them out.
*EDIT* After some thought...I think I did put the socket and ratchet in there, and just use the shock itself to work the bolt loose, just keep wrenching back and forth on the shock till that bolt loosens up, then, there is only just enough room to fit your hands in there to tighten the new shocks. Good luck
__________________
Quote:
Quote:
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting DD: 94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 200k on the clock Project: 91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 219k on the clock. It's becoming an addiction. Last edited by Team420; 07-07-2008 at 06:35 AM. |
#25 (permalink) | |
Quote:
I will say that removing the rear shocks has got to be the worst job I've done on the 4Runner to date. First, I used a cut-off wheel and sliced into the fluid reservoir. Yuck! The sawzall did me right in the end and the second shock came off nice and quick. MadCityRich
__________________
Alright, when I say your name, you say 'here.' And we will assume 'here' is short for 'here I am...rock you like a hurricane. -Ignignokt |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Top shock bolt not reuseable (front shocks) | aaronk | 86-95 Trucks & 4Runners | 5 | 02-10-2008 08:58 AM |
| Removable Top Bolts? | PioneerPete | 86-95 Trucks & 4Runners | 12 | 10-02-2007 09:39 AM |
| 3vze top end rebuild (head bolts) | Desert Rat | 86-95 Trucks & 4Runners | 10 | 01-01-2006 09:24 AM |
| flatbed and shock rear shock mount | 934rnr | The Fab Shop | 28 | 07-22-2005 09:49 AM |
| How many bolts do you leave in for a 1st Gen Top? | gohawks | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 05-17-2005 07:57 AM |
