how to get cam sprockets off on v6?
Old 01-11-2005, 03:12 PM
rivercat's Avatar
this is the last thing holding me back from pulling my heads and i can't seem to get the damn bolts loose... standard threads right? i don't have the special toyota tool, usually i'd jam in a screw driver or crowbar but this hasn't worked. i've heated the bolts with a torch to release any locktite and pounded away with an impact wrench... any idea's? anyone in the northbend, wa area have the special tool they would loan/rent me? i want to pull my heads so i can order parts before being stuck up on snoqualmie pass at work for the next week.....
dug around on the forum, anyone have a sickly huge pipe wrench?
do i have to remove the cams to remove the heads?
Old 01-11-2005, 04:05 PM
StevieC's Avatar
I just went through that arduous task a few weeks ago! It's a real PITA! You need the special tool. I used a chain wrench with an old belt to protect the teeth. I broke a 1/2 inch socket trying to break torque on the nut so I had to use an impact socket. Still it took two 200+lb guys with cheeter pipes pulling with full strength. Finally got them off but I dimpled the teeth on the sprocket very slightly. The tool is $30-40 online I would get one. I'll try to find the link for the tool. It is right hand (normal) threaded.
Steve
Old 01-11-2005, 04:07 PM
StevieC's Avatar
Cams have to come off to remove the heads unless youi want to cut the rear timing belt cover.
Old 01-11-2005, 04:11 PM
StevieC's Avatar
http://www.thetoolwarehouse.net/shop/SP-96800.html
For the tool. $31.48
Steve
Old 01-11-2005, 05:59 PM
rivercat's Avatar
thanks man, i just got them off had to use some friggin huge wrenches and like a 100 feet of cheater bar.....
LittleUgly
15
01-02-2020 01:30 PM
moparbay
10-06-2015 09:24 AM
Jdgarrison
10-01-2015 05:22 PM
tylermx71
09-29-2015 08:49 PM
whiteyota93
09-29-2015 02:31 PM
Quick Reply: how to get cam sprockets off on v6?
