Hot engine
Old 10-19-2003, 07:04 PM
otter's Avatar
Hot engine
Any thoughts on my 96 4Runner that can't cool the engine well enough with a 1st Gen SC. I was thinking a Flexfan to help suppliment. Running is fine, its that traffic that sends the needle skyward. Any info. or comments.
Old 10-19-2003, 07:29 PM
MTL_4runner's Avatar
I would go with an electric fan like a flex-a-lite 210 if I was going to do anything fan-wise. I doubt the fan is the root cause of the overheating. Is the vehicle running lean at all? Any codes in the ECU? Do you have the proper mix of fresh coolant in there? Is the radiator free of obstructions? Is the thermostat sticking? Does the rad cap hold pressure? There are any number of questions to ask yourself but be careful of just using a bandaid on the sympom. Hope this helps.
Old 10-19-2003, 07:39 PM
use a ford taurus elec fan out of a sho car. 50 bucks at pick and pull and will put cool a flexalite
bigjstang
08-25-2021 12:41 AM
the1998sr5
15
07-14-2020 08:35 PM
Poncho0206
07-10-2015 06:21 PM
Avenged
07-09-2015 07:55 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Hot engine
