YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 06-11-2009, 04:34 PM   #1 (permalink)
Personal Sales Rating: (0)
cpizzle42's Avatar
horrible CV shaft luck
So I am running Camburg UCA’s with sway-a-way coils, so I know I have more travel which puts my CV shafts in more of a bind. Although since I have owned this runner (5 months or so), I have replaced the original cv's, and now I am on my 5th Napa unit. All the stores in my area are starting to not believe my BS about not off roading with their CV's when I go to return them with the warranty. So what can I do? I put two new ones on two weeks ago, went and ran box canyon and coke ovens trail and the passenger side boot is gone and grease is everywhere again and the driver’s side has a whole bunch of play in it. Does anybody make a set of built proof CV's for the '96 Runners? Or am I just going to have to do a SAS for as hard as I play?
__________________
1996 Runner limited, V6 4wd, 5sp 5.29 gears Supercharger/under pulley/ URD's fuel/timing kit
Suspension-Sway-a-way 2.5 coilovers and camburg uniball uppers, gusseted spindles, strapped, Cruiser springs and heim'd links in rear.Tires and wows-35x12.50 Goodyear MTR's on 15x8 black steels, cut fenders and cut back firewall.
Misc-spool in rear, Cobra Cb, CO2 tank, Bud Bulit Skids, K&N intake, flowmaster exhaust. Power Steering Cooler, 140 amp alt, 8K winch, Superior axles, aluminum fuel cell.
cpizzle42 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 06-11-2009, 04:40 PM   #2 (permalink)
wunbigtacoma's Avatar
Do you have a diff drop? If not get one
__________________
95.5' Tacoma ext cab v6
5spd,Electric fans,Intake,Exhaust,
Fabtech C/O's,285 Trail Grappler's
Lock Right rear
10K Hid's
<Matt>
wunbigtacoma is offline
Old 06-11-2009, 04:43 PM   #3 (permalink)
Threadstarter [OP]
cpizzle42's Avatar
I would but I have Bud Built Skids. I wont be able to run those with the diff drop right?
__________________
Old 06-11-2009, 05:54 PM   #4 (permalink)
TC4RNR's Avatar
BB skid was designed to work with either 1" diff. drop or no drop. and you should not crank that coilovers up over past 2.5" lift. if you want more lift, go with either mid travel or long travel kits, with aftermarket UCA's and LCA's and CV axles. or, manual hub conversion.
__________________
94 4Runner, SR5 3.0V6, 4WD, 5spd: SOLD
99 4Runner, SR5, 3.4L 4WD, 5spd. LC80 wheels, SS 1.2 lift, Marlin 1200 Clutch, ARB front bumper, BruceTS rear bumper, Tundra Brakes, Brembo rotors, Stainless skid, Stubb's HD-SKO sliders.
04 4Runner SR5 V6 4WD. 265/75/16 BFG KO, FJC coils and silver Bilstein shocks, Scion H/U.
TC4RNR is offline
Old 06-12-2009, 08:50 AM   #5 (permalink)
troyboy162's Avatar
so a total of 6? how much lift are you running up front? if you are in the 2.5-3.5 range then you need to look at your driving manors. slow, steady, and straight keeps the cvs together. steering cranked, suspension drooped, and gas pedal makes them break the most.
__________________
www.ultimateyota.com
troyboy162 is offline
Old 06-12-2009, 09:13 AM   #6 (permalink)
Threadstarter [OP]
cpizzle42's Avatar
I have no idea how much lift I got them at right now. I did not measure before and after. I will def. order a dif drop today, now that I know the skid will work with it. And troy, about my driving manors, I am fully aware of what a cv does at full droop, 4L, fully turned, and with a little gas, aint my first rodeo.
__________________
Old 06-12-2009, 10:12 AM   #7 (permalink)
crolison's Avatar
diff drops don't do jack
just lower your front co's, are your fins touching at ride height?
i don't know what your doing, but I wheel pretty good and haven't totally screwed a cv over yet, and I am locked in the front. and yes i have been drooped, fully turned, locked, on the gas and haven't broken anything yet. as guess its all the traction we don't get out here.
__________________
97 tacoma - 3' of sheet metal
99 4runner - 5spd dd
crolison is offline
Old 06-12-2009, 11:54 AM   #8 (permalink)
Bighead's Avatar
What were you doing when you blew the CV? Was it the same situation for each of the blown axles?
I'm guessing your SAWs are set too high.
__________________
2004 Land Cruiser -- OME/Slee Suspension | Slee Dual Battery | Slee Armor (Front, Rear, Sides and Belly) | Nitto TG 285/75-16 | ARB Drawers
Bighead is offline
Old 06-12-2009, 05:42 PM   #9 (permalink)
Threadstarter [OP]
cpizzle42's Avatar
I am just tearing the inner boots, then gets in there and locks them up when I am wheeling. And I dont know how my co's can be too high, my truck sits like a stink bug right now how they are. Crolison what do you mean fins touching at ride height?. I just finished putting the new cv in. I ll tell you what, those dudes at napa hate me, they see me come in and they just stare at me, like "really? again?" haha I am proud to say I can a change a cv out in under 15 minutes now.
__________________
Old 06-12-2009, 05:58 PM   #10 (permalink)
Bighead's Avatar
Once you get everything back together again and sitting on rubber, take a look at the CV boots. Crolison is asking if the fins on the boots are touching when you look at them.
Did you do the lift or was it on when you bought it?
__________________
Bighead is offline
Old 06-12-2009, 09:44 PM   #11 (permalink)
Threadstarter [OP]
cpizzle42's Avatar
I'll look tomorrow to see if the fins are touching on the boots.
The truck was bought stock with worn out coils.
The SAWS are not even jacked up that much.
Do you think I should do a 1'' diff drop?
Just looked today and the other shaft the has been in there for two weeks has slop in the bearings. Am I just having bad luck with napa units?
__________________
Old 06-13-2009, 04:22 AM   #12 (permalink)
Bighead's Avatar
A diff drop couldn't hurt but I would not count on it to keep the same issue from happening.
What do you mean by slop in the bearings?
If Steve wasn't on vacation I'd say run by Sonoran Steel and have him take a look at it.
__________________
Bighead is offline
Old 06-13-2009, 07:04 AM   #13 (permalink)
TC4RNR's Avatar
wanna try this?
http://www.allprooffroad.com/9602frontsuspension/282
by the way, are you running with sway bar removed?
__________________
TC4RNR is offline
Old 06-13-2009, 11:15 AM   #14 (permalink)
Threadstarter [OP]
cpizzle42's Avatar
What I mean by slop in the bearing is I can grab the shaft of the cv between the boots and wiggle it around. I am guessing that not suppose to happen?
Those long travel boots from all-pro look like something that could def help my problem. But how in the heck would you fit that small end of the boot of the large part of the cv?
__________________
Old 06-13-2009, 11:27 AM   #15 (permalink)
troyboy162's Avatar
Quote:
the boots tearing are more of an indicator of some other front end issue. alot of guys tear boots and dont repair them for up to a year without breaking cvs. your at 6 cv's in 5 monthes and apparently arnt beating on the truck. defiantly post up some pictures of your cv angles with the truck sitting on the ground and maybe some jacked up to show full droop. also im sure the napa units arnt quite as tough as OEM but that dosnt account for 6 dead ones either.
__________________
Old 06-13-2009, 11:28 AM   #16 (permalink)
Threadstarter [OP]
cpizzle42's Avatar
And I took the sway bars off. I figured why spend over of 2 grand on suspension, then have sway bars not let the truck do its thing. ya know?
__________________
Old 06-13-2009, 01:10 PM   #17 (permalink)
Threadstarter [OP]
cpizzle42's Avatar
At ride height-
http://i255.photobucket.com/albums/h...2/cvangle2.jpg
At full droop-
http://i255.photobucket.com/albums/h...2/cvangle4.jpg
__________________
Old 06-13-2009, 01:23 PM   #18 (permalink)
TC4RNR's Avatar
not quite, why people spend twice of that money on LT conversion also put on limit straps.
TC long travel kit:
Parts Included:
Upper A-Arms W/ Bushings, Uniballs, & Clips
Lower A-Arms W/ Bushings, Shock Mounts
Tie-Rod Extensions
Braided Stainless Brake Lines D.O.T. Approved
Grade 8 Hardware
Adjustable Limit Straps & Mounts
Click the image to open in full size.
base on the picture of the full drop, nothing is gonna save the CV unless you cure that angle.
__________________
TC4RNR is offline
Old 06-13-2009, 01:28 PM   #19 (permalink)
SnowRunner98's Avatar
There is your problem brutha! I did that many a time on my 03 taco before I got a diff drop, and turned my C/O's down to 2in. At 2.5" I was wearing them out like a champ too. I'm running the same front suspension as you on my front , just need to get off my rear and install my UCA's. I have them set at 2in. with diff drop and I have put a grip of miles on mine. Haven't wheeled the crap out of my truck yet. My rear be draggin' ha
__________________
98 runner SR5, flowmaster 40, K&N deckplate ISR,Poly rack and pinion bushings,1in. dropdown spacer, 2.5 swayaways c/o, Camburg UCA's. 285's 16x8 black wheels, Built front bumper,Tundra Brakes! Stereo, and alarm. 99 headlights
Wish list(rear lift, 4.88's,E-locker, rear bumper,sliders)
SnowRunner98 is offline
Old 06-13-2009, 01:31 PM   #20 (permalink)
When i bought mine from camburg, they said the bottom of the shock will be the bottoming out factor, "Do I need limit straps with this set up?" and they told me no.
__________________
Yotatech
4WD Truck
Paid Advertisement
Tags
4runner, adjustable, camburg, coilovers, cost, cv, grand, limit, replace, replacement, shaft, strap, swayaway, tundra, uca
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
wish me luck forbiddenera 86-95 Trucks & 4Runners 6 09-25-2008 12:14 PM
Horrible Noises, Horrible Smells Brought a tear to my eye and my heart dropped. 91muddog 86-95 Trucks & 4Runners 45 07-18-2007 03:41 PM
Wish me luck... ErikJeanna Off Topic Talk 27 09-01-2005 09:00 PM
Tight turns, and a horrible, horrible sound. ATP4984 Maintenance & Repair Archives 8 04-17-2005 11:17 PM
wish me luck..... jjdeneen Off Topic Talk 10 12-03-2003 07:30 AM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
