High RPM Vibration
Old 04-24-2011, 10:06 PM
NwRunner's Avatar
High RPM Vibration
1999 3.4 Auto 4Runner. 50k on Engine, 200k on everything else.
I am getting nasty RPM based front end vibration that starts at 3.5k and gets progressively worse until it peaks at 4.5-4.7K then it usually shifts. I just swapped a new motor in and everything seems to be secure. Motor mounts and exhaust are all tight, and i marked every bolt on the flexplate/spacers so the weight should be dead on.
I just took it out and the vibration was so bad that it started to rattle the dash before it downshifted. Its pretty much narrowed down to flexplate for me, but i pulled the cover and everything looks fine... help!
Old 04-24-2011, 10:09 PM
totally a bro
Staff
vital22re's Avatar
did you pull the drive shaft? have you checked the u joints? put it up on jack stands and i'll come over and watch the driveline spin.
Old 04-26-2011, 01:15 AM
NwRunner's Avatar
Turns out it was an out of balance fan??
It blew up today, atleast i know what the problem was!
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
redghost.308
California SoCal
07-16-2015 07:46 AM
Quick Reply: High RPM Vibration
