High idle for a long time after start
Old 09-08-2005, 10:51 PM
Glina's Avatar
Hi everyone,
Here is my problem.
After cold start my '91 4Runner manual trans. (3.slow) idles around 1500~1700 rpm, but the problem is that it idles like it for a quite long time. I suppose that there is something wrong with cold start injector system or engine temperature sensor. How to check it? Maybe problem is caused by something else?
Old 09-08-2005, 10:54 PM
jimbo74's Avatar
how long is quite long time? the engine does run a lot higher at initial startup as designed.... in colder climates, it will take longer to get to operating temp than warmer climates... also city stop and go traffic takes longer to warm the engine up as well
Old 09-08-2005, 11:00 PM
Glina's Avatar
It idles much higher than it should for about 10 - 15 mins even in summer.
It is also hard to start after I turn it off before it warms up well. Cranks very well. Starter and battery are perfect.
Old 09-09-2005, 09:48 AM
Steveh29's Avatar
There's a coolant passage that runs through the throttle body. Make sure it's not clogged.
Old 09-09-2005, 09:54 AM
dwh91102's Avatar
check what steve said, also the cold start injector may be sticking
Old 09-09-2005, 10:52 AM
Steveh29's Avatar
I've found that when the temp sensor for the computer (not the temp gauge) goes bad, it doesn't high idle for a long time - it runs like crap all the time. Still, it may be worth checking.
Old 09-09-2005, 11:34 AM
hill's Avatar
my 91 idles around 450-550RPM
Old 09-09-2005, 12:25 PM
Flamedx4's Avatar
That's too low even when it's warmed up! Should idle at 800 rpm.
Fast idle spec is really high, like 3000 rpm. Mine only high idles for a 30 seconds or so, even in winter. And I don't think it hits 3k!
Old 09-09-2005, 07:11 PM
CoedNaked's Avatar
Yeah the 3.0 generates a lot of heat. My truck engine's cooling system is in top condition (fairly new water pump, new rad, new coolant, hoses, etc.) and even my truck warms a lot faster than I remember other vehicles I've owned and/or driven in the past.
Old 09-10-2005, 03:48 AM
Glina's Avatar
Thanks. I'll check cold start injector and this water passage, and let you guys know.
Old 09-13-2005, 05:55 PM
hill's Avatar
whats wrong with a low idle?
Old 09-14-2005, 09:20 AM
Flamedx4's Avatar
Nothing really, long as it runs fine. Can have a problem with fouling the catalytic converter in some cars, can foul plugs in some cars, can have stumbling issues off-idle when hitting the gas, making it harder to pull out smoothly, that sort of thing.
BTW - I checked and mine fast idles when cold at 1800. Books says 3000 but MAN that's high!
Old 09-14-2005, 10:51 PM
L33T35T 4Runner's Avatar
problem with a low idle? My truck is 10 years old and i set my idle perfectly to 800 when it's warm. It idles perfectly smooth, you cant hear it at all. I would want the correct idle just so it runs smoothly. I think those toyota engineers know a little something more than you do
as for the original question: if you drive it right when you start it and as soon as it's warm, does the idle go down to normal? sounds like it might just be acting normal. i know that if i start cold in the morning, even if i let it sit for 10 minutes to warm up, it'll stay at a higher idle until i touch the gas, then it'll go down
Old 09-14-2005, 11:44 PM
Glina's Avatar
no. it idles high even when it's warm and after driving it. It has to be almost hot to idle at 800.
It idles smooth though.
Old 12-31-2005, 05:20 PM
Changsta's Avatar
On the TB, is the coolant passenger inlet located on the side facing the firewall; underneath the TB's electrical connection? I have a high idle problem as well.
And uh, sorry for reviving a dead thread.
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
vasinvictor
01-20-2016 12:39 PM
slacker
13
09-06-2015 06:14 AM
Quick Reply: High idle for a long time after start
