| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Staff
help... upper 90s and no AC...
#2 (permalink) |
freon on r134a? freon is r12 which is the older stuff
r12 is not compatible with r134a, unless the system was converted..... |
#3 (permalink) | |
Staff
Quote:
#4 (permalink) |
Is the compressor even turning on when its blowing warm ? You really need to check both hi and low side pressures to get an idea of what the system is doing.I'd recommend taking it to a shop to have it checked out.
#5 (permalink) |
1994 and up 4runners have the new freon.
__________________
1993 4runner V6,SR5, 5-Speed, 4WD, Amsoil, Downey HD's. 1982 FJ60 Landcruiser, 120K, totally stock....work in progress |
#6 (permalink) |
Go out start your Runner, open the hood and turn the AC on. Is the compressor turning/cycling? Is the small electric fan coming on at the same time? If these are working, look at the sight glass on top of the dryer. This is located on the right side and in front of the radiator (looking into the engine). Are there bubbles in it? The 134 could still be low even though there is pressure in it on the low side. Get a Chiltons or eqivalent book for your Runner. It has a section on AC troubleshooting. I think there is also Chiltons just on AC.
__________________
Chris Mine-94 SR5 4-Runner, 3.0, 4X4, Aisin Hubs, Yakima Load Warrior, 210k Miles | Wifes-99 Limited |
#7 (permalink) |
Staff
UPDATE: today when i went out and started up my 4runner, turnd the AC on max and sure as , it was ice cold... any reason why it would not work one day and then be cold the next?
#8 (permalink) |
Evacuate some of the freon. When it gets hot outside (and inside the engine compartment), the pressure increases internally and in your case (because you're at the threshold of being overfilled), causing the high pressure A/C sensor to kick the compressor off intermittently.
Let it down to about 30-35 PSI and report back. You can do this by sticking a thin screw driver into the low-pressure side cap and pushing down the valve inside. Be careful that your face is away from the direct upstream path of that valve. I realize this is technically illegal, but he's draining just a few PSI and will save him money and time of getting the entire system diagnosed and "repaired".
__________________
Preston Edwards 1992 4Runner SR5 V6 4WD (5 Spd.) 246,000 miles & counting 2" Downey coils, 32x11.5x15 BFG A/Ts, Rockcrawler Series 51 wheels, Magnaflow exhaust, Yakima roof rack, ARB bull bar, SAW Torsion bars, (4) PIAA 520s, Cobra 18 WX ST II CB w/ Firestik antenna, hp iPaq GPS 2008 Toyota 4Runner Limted 4X4 15,000 miles & counting Last edited by rpeAMP; 07-06-2004 at 05:13 PM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| IFS 4wheeling(pics from today with 90s 2dr) | vwfastg60 | Trip-Trail Reports & Photos | 28 | 11-30-2006 05:36 PM |
| Early 90s Toy truck and 4runner alignment questions? | Road Head | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 05-17-2005 02:40 PM |
| 90s 4runner and truck questions | r854rnr | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 10-08-2003 04:51 PM |
| OT: Late 90s Corolla vs Late 90s Chevy Prizm | mtnbkr | Off Topic Talk | 4 | 03-06-2003 12:00 PM |
