| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
#2 (permalink) |
If you honestly want your rig to be more trail worthy and not just look like it, the first thing you want to do is get a rear locker.
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#3 (permalink) |
I agree w/ adam, a rear locker and 31's on a runner is a good setup. If you can find a used 3rd member w/ a locker for cheap, it is very easy to swap in
#4 (permalink) |
What's a "crappy custom 3 1/2 " Lift"? As long as it's not an unsafe setup, it will allow you to run 33s. Rear locker/limited slip etc is a great bang for the buck in trialworthiness. Otherwise, remove the lift and run 31s with a rear locker. Most trailworthy for least money. Then build from there as time/money permits.
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil |
#5 (permalink) | |
Quote:
#6 (permalink) |
Ok I had my lift check out it's kewl. I was wrong about the whole crappy part. But my next ? is my T-Case hangs down real low I was wondering if there was a way to raise it or cover it?
#7 (permalink) |
budbuilt.com has low profile tcase crossmembers that can also raise the tcase, if you want. even with no tcase lift, it'll give you a couple more inches of ground clearance there
__________________
94 4x4 yota truck |
#8 (permalink) |
But unless you are going to get very hardcore off road, don't worry about it. They aren't getting destroyed by normal wheeling - it looks low, but look under any non-Yotas and check *their* height! Its what you notice when you look under there, but it's still 2 feet off the ground... If funds are low - that tcase crossmember should be about last on your $$ list.
__________________
| Tags |
| 4, 4runner, forum, install, lift, ohio, runner, sale, toyota, trailworthy, truck, yota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| WTB: Frame for short body 84-90 yota truck! | dirtfarmer | The Classifieds GraveYard | 4 | 05-02-2007 06:21 PM |
| my 90 yota | mrtejman | Trucks, 3rd gen-'89 to '95 | 0 | 06-05-2006 10:19 PM |
| What wheels will woork on the 90 yota 4x4? | LOCKnGO | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 09-04-2005 11:54 PM |
