| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Help Just cleaned engine bay and it runs very rough now
__________________
-Eric 2002 SR5 4WD Goodyear Wrangler Duratrac 265/75/16C Deck plate + ISR OME 881/890 Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims |
#2 (permalink) |
I might add it only shakes and runs rough when its in gear.
__________________
#3 (permalink) |
I am assuming when you sprayed it off the engine was cold.
Check the distributor cap, might have water in it. If compressed air is available I would blow out all the sensor connections like TPS, distributor, O2.
__________________
'86 4runner 22RE, 5-speed, LC Street EFI head w/ cam, LC Pistons, ARP Head Studs, Downey header, Dynomax 2 1/4" full exhaust, VDO water temp guage, 01-03 Tacoma cd\tape radio with 10" Bazzoka, Downey 2" rear springs, GDI radiator, Torus fan DONE!!!! '68 Ford Mustang Fastback Daily driver with a built 289 and a streetfighter trans.(Retired) 98 Subaru Outback-Took over daily driving duties MicroMatic.com Waco93.com |
#4 (permalink) |
it had been cooling for about 30 min when i sprayed it so it wasn't hot but it wasn't cold. Im not super familiar with where everything is but ill find it and check it out.
__________________
#5 (permalink) |
No distributor on the 3.4s.
__________________
'99 4Runner Highlander 4wd E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub |
#6 (permalink) |
well i let it sit for a while and idle then took it up the street. Seemed to get better then the CEL came back on and it was rough idleing.
__________________
#7 (permalink) |
its almost like its miss firing or something. It idles rough, then set smooth then rough again, its fine ~2500rpm without being in gear. But it wont come down from 2000 slowly. It just drops like a rock from 2000- ~1000.
__________________
#8 (permalink) |
Pull the codes and see what the CEL is telling you. Probably just water in the connection of whatever the CEL is having a problem with.
__________________
#9 (permalink) |
How do i get the codes pulled?
__________________
#10 (permalink) |
You should have OBDII so you will need a code reader. Autozone will let YOU use thiers for free. You have to hook it up and everything cause they want no liabillity for your vehicle but its not that hard.
__________________
#11 (permalink) |
so if i get it to auto zone i just plug their thing in and it will spit out the code for me or is there more too it then that?
__________________
#12 (permalink) |
Thats it, they will hold your credit card and license while you do it. So make sure to have them.
__________________
#13 (permalink) |
Correct, all you have to do is take it to Autozone (they check it for free).
__________________
~Eric 1991 4Runner 3.0L 4x4 Black, 31" Michelin M/S tires, OME-901's 1992 Lexus SC400 4.0 V8, Green with Tan interior (donor) (PM me for parts) Near Future: FI 1UZ swap. (June) Far Future mods: F/R Lockers, SAS, 35's. UZswap.com - A discussion forum dedicated specifically to swapping UZ engines into Toyota trucks and 4Runners |
#14 (permalink) |
pull your coils and see it there water sitting ontop of your plugs
#15 (permalink) |
WD-40 is your friend.. I would start with the coil connectors and go from there. Just pull them off, spray WD-40 into the connector (which disperses the water) and plug it back in.
#16 (permalink) |
Same happened to me and i had misfire in cylinder 4, it somehow managed to foul all of the spark plugs/ wires.
#17 (permalink) |
just replaced the wires and plugs?
__________________
#19 (permalink) |
I degreased my Runner's engine today also, but I put grocery bags on alternator, K&n, and a few electrical parts to make sure I didin't get water anywhere...she's just smokin' a bit after I let er run to dry off..Is this normal burn off?? sorry to hi-jack just curious--it smells like degreaser!
__________________
97' 4RUNNER SR5 4x4 Lift:OME 881's OME Fronts w/ TOYTEC top out spacer, OME LC Rears 2in. 4crawler BL, SS Diff drop, Custom welded drop bar Performance:Yellow Top,Custom Dual Vortex Exhaust, Magnaflow Hi-flo CAT, K&N FIPK, Diff Breather Mod Wheels & Tires:315 16x9's on MOTO METALS Lights:Silver Reverse Glow Gauges, Hella 500's Armor:Trailgear Sliders, Taco ARB "Sounds stupid. . .sign me up!" |
#20 (permalink) |
Im going to try and get it to auto zone tomorrow. Its not what i would call safe to drive though.
__________________
#21 (permalink) |
Yeah, pulling codes is easy you'll just have to look then up and sometimes it just gives you an area of things to check. Sounds like water got in the coil packs for the plugs...
__________________
#22 (permalink) |
I think im gonna replace the coils tomorrow. Any suggested brand?
__________________
#23 (permalink) |
Replace the plugs
Fouled the plugs.
__________________
miles WTB: 3rd gen 4 runner 2002-1997 Athens,Ga |
#24 (permalink) |
ok so the plan is to replace the plugs and wiring tomarow. Can i get NGK's at auto zone, and what kind of plug coils should i be looking for?
__________________
#25 (permalink) |
Try plugs and wires first. Coil packs are $80 and are probably unnecessary. I had the same issue (code was a misfire in one of the cylinders) and just did the plugs and wires. Fixed it completely.
Use some dielectric grease on the plug wire to plug connections and you'll never have to worry about this again. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Changed plugs and now it runs rough. | Beartracker | 95.5-2004 Tacomas & 96-2002 4Runners | 24 | 03-12-2007 12:01 PM |
| 3.0 new engine runs rough | Chapman88SR5 | 86-95 Trucks & 4Runners | 1 | 11-16-2006 09:20 AM |
| runs rough when warm 3.0 | Glina | 86-95 Trucks & 4Runners | 23 | 05-23-2006 11:55 PM |
| engine runs rough in 4th and 5th | Blakbat | 86-95 Trucks & 4Runners | 0 | 10-06-2005 08:51 PM |
| 94 4 runner runs rough | rocknron | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 02-15-2003 12:05 PM |
