Help with head unit
Old 11-08-2003, 08:06 PM
fooddude's Avatar
Help with head unit
i just installed my new sony head unit on my 95 4runner today and i got all the colors of the wire's matching and all but the problem is my internal lights on my dash wont turn on anymore. Everything works except for that. Anyone now a solution because i would reallly like to see how fast im going at night.
Old 11-08-2003, 08:53 PM
Jonathan's Avatar
You grounded the system. Take the unit back out and disconnect the orange wire(it should be orange, i think) and tape it up. That wire when connected will ground the system. Then check your fuses in the engine bay and replace the one you probably blew out. Should be the dome fuse i think.
Old 11-08-2003, 09:24 PM
fooddude's Avatar
okay thanks because i now i connected the orange wire.
Old 11-08-2003, 10:22 PM
Rymin929's Avatar
More than likely you hooked up the ground from the radio to the illumination wire (green) at the factory radio harness...Bump to the previous post otherwise...
Old 11-09-2003, 02:32 PM
fooddude's Avatar
im still having problems!! I took the orange wires apart from one another and checked all my fuses and the are all fine so what could the problem be me and all my friends are all stumped.
Old 11-09-2003, 03:17 PM
Cebby's Avatar
Did you plug your dimmer control back in? (Wire from the control knob on your dash needs to be plugged in for the dash lights to work...)
Old 11-09-2003, 03:59 PM
Jonathan's Avatar
What happened when you seperated the orange wire?
Old 11-09-2003, 05:53 PM
fooddude's Avatar
didnt seem like it did anything just the same results.
Old 11-09-2003, 06:31 PM
2001Millrunner's Avatar
should be the orange wire, get a voltimeter, connect it, see if it comes on and off when you shut off your lights on/off. everything else is a breeze, you just need to cut out the orange wire and find the interior light wire
Old 11-09-2003, 07:02 PM
fooddude's Avatar
so i cut the orange wire completely off or just seperate it from the other orange wire.
Old 11-09-2003, 07:04 PM
Cebby's Avatar
Did you check the gauge fuse?
Old 11-09-2003, 07:35 PM
fooddude's Avatar
yep ive checked nearly every fuse that has anything to do around the guages.
Old 11-09-2003, 07:40 PM
Cebby's Avatar
You checked this also?
Old 11-09-2003, 07:46 PM
fooddude's Avatar
i am sorry cebby but im not good at this electrical stuff which wire from my dash im pretty sure i plugged all of them in that i unplugged.
PS thanks for being patcient with me so far.
Old 11-09-2003, 07:52 PM
Cebby's Avatar
I've scratched my head for a good while and tore my dash apart a couple of times when forgetting this one. Easy to forget - that's why I asked. There might be a problem with the plug for this... You can try taking a small wire and jumping the two terminals in the dimmer wire connector that comes from the vehicle harness. That will rule the dimmer out as a problem...
Good Luck.
Old 11-09-2003, 07:57 PM
fooddude's Avatar
i see too orange wires that say dimmer positive and dimmer negative am i supposed to do anything with these
Old 11-09-2003, 08:06 PM
Cebby's Avatar
That all depends - WHERE are you seeing these? In the radio harness? Do you have either of these hooked up right now?
kgcwb44
01-29-2023 10:02 AM
mussy01
12-13-2016 08:20 PM
o2raybid
09-04-2015 12:45 PM
themightykhoner
08-11-2015 07:37 PM
toofly1999
07-25-2015 07:09 PM
Quick Reply: Help with head unit
