| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Help getting trac bar re-installed after 2" lift
#2 (permalink) |
have someone sit on the rear bumper while you try to put the bolt back in. You might have to have them jump/push up and down on the bumper to get it to line up again.
John
__________________
'97 4Runner SR5 Front: Tundra Coils/Tokico Trekmasters | Rear: LC Shocks & Coils + SS rear "fixes" | Custom Sliders 285/75 Maxxis Bighorn Radials | Retrofit E-Locker | TJM T15 | Custom Rear Bumper | Warn m8000 Last edited by Mojo_Risin; 05-23-2008 at 10:18 AM. |
#3 (permalink) |
You can't get it back on because the bar is now too short. It's a trigonometry thing, when you lengthen one side of a triangle you have to lengthen one of the other sides. If you use the original bar your axle will be off centre.
You need one of these http://www.sonoransteel.com/store_adjustable_bar.html |
#4 (permalink) |
I do agree with eric-the-redon getting the adjustable but if you really want to get the stock one back on try a big flathead screwdrive and start prying. It worked on my friends 90 4runner b/c he didn't want to get a new trac bar. So far everything has held up!
__________________
1986 4Runner Automatic rebulit 22re OME leaf springs BJ spacers Edelbrock IAS shocks 31x10.50 Pro comp Mud Terrains |
#5 (permalink) |
Why did you remove it? I didn't need to remove my panhard bar.
But, like spdjnky said, I'd recommend the strong screwdriver trick to line up the holes, then hammer in the bolt. Last edited by kmcaprice14; 05-23-2008 at 01:37 PM. |
#6 (permalink) |
If you can get someone or two to stand on the bumper it should work.
__________________
1996 4x4 3.4L 4Runner on 35's - 6" of lift, MTR's, E-locked, ARB Tacoma Bumper, Sliders and a cut off tail pipe. 1966 FJ40 - SOA with stock springs, stock 1F motor, and a smelly tailpipe. |
#7 (permalink) |
I have about the same amount of lift and I reinstalled mine before I put the tires back on by jacking up that side of the axle until it lined up.
__________________
John '96 4runner SR5, Tundra TRD / Trekmasters and Downey / OME, 265/75/16 Revos |
#8 (permalink) |
You can try using one of those motorcycle tie down ratchet straps to pull the axle over, then slide the bolt in...worked for me.
__________________
Why??? Because I Can !!! My wife knows the difference between a body lift and suspension lift!!!, does yours? 96 4Runner, E-locked, TRD Tundra/ FJ80 coils, Bilstien 5125's, 285/75/16 MTR's. Lots more custom parts coming. 87 Supra 1jz 420 hp Check out my website: www.bicperformance.com |
#9 (permalink) | |
Quote:
We tried a ratchet strap and broke it, but then used a come along to pull the axle toward the passenger side and that did the trick. I later realized that If I would have used my brain and disconnected the sway bar then I wouldn't have had to disconnect the trac bar anyways. Oh well, If I didn't mess up myself then I wouldn't be able to help you!
__________________
1998 Toyota 4Runner Limited 1A5 V6 3.4l 4x4 w/ RR DIFF LOCK Exterior: TRD Tacoma wheels, Spidertrax spacers, 20% Tint, Coleman Safari Rack, clear corner lenses, custom dents Interior: Alpine CDA-9883, Polk MOMO 6.5", Infinity Reference 5.25", Memphis 16-STT150 2 channel amp, custom mud Offroad: OME 3" lift (881/890), 1" diff. drop from Toytec, Tacoma whip antenna, extended rear diff breather, gray wire mod, 285/75/R16 BFG M/T KM2 |
#10 (permalink) |
Little old, but when i put my cruiser coils in my 2nd gen(should be simmiliar), long story short we ended up disconnecting the panhard bar, with no help getting the springs in but i was trying to make a point to my cousin.
Getting it back on was fun , maybe not the safest way but it worked good!Ended up taking out my tow strap, connecting it to my tow hitch, and had my cousin pull it to the side slightly with his truck. THis made it go on easy! Anywho, now i need to buy a bracket to extend it cause the drivshaft hits the gas tank during axle travel. Maybe that will help someone out in the future, just thought i would throw it out there.
__________________
Mike 1990 4runner: 3.4 swapped, 5-speed, sas'd, Rear leaf swap, Locked, 5.29's, 39.5" iroks on Beadlocks, Armor'd Longfields, Duals coming soon: My build thread http://www.yotatech.com/f152/904_run...thread-158746/ http://www.treadlightly.org/ http://www.pirate4x4.com/tech/billav...ery/index.html |
#11 (permalink) |
I just put my axle on jack stands and lowered the lift until it went in.
__________________
97 4runner, 2.7 5speed 4wd, 5.29, 33 horns armor locked lifted heavy SOB broken front and rear swaybars My Profile.. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Installed Rear Hi-Lift/Light Bar | ATC | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 04-15-2007 07:17 PM |
| Please Read if you have installed a 3rd Gen PanHard/Trac Bar drop bracket | sschaefer3 | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 03-15-2007 07:24 AM |
| Sonoran Steel 2nd Gen 4Runner Drop Trac Bar/Lift Proportion Valve Bar | sschaefer3 | Vendor Advertising | 55 | 11-20-2006 06:31 AM |
| 3" lift installed | dave89144 | Offroad Tech | 7 | 09-27-2005 07:43 PM |
| 2nd gen trac bar/ panhard bar removal | Y2Krunner | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 08-04-2005 02:05 PM |
