help! fuel leak after reassembling from head gasket job
Old 08-17-2005, 03:22 PM
jscarrozzo's Avatar
Well i went to start the truck(93 22re)...and there is gas spraying from where the fuel line/fuel rail connect together. I just got done putting this thing together from a head gasket job. I didnt remove the banjo bolt at all... any ideas?
Old 08-17-2005, 03:29 PM
anthony1's Avatar
did you reverse the lines? there's the gas intake line and vapor return line...
Old 08-17-2005, 03:34 PM
jscarrozzo's Avatar
i never took the line off the fuel rail..i connected it right back to the fuel filter(the opening more towards the rear of the truck) maybe i put the new fuel filter on backwards? I dont think that would be the problem, because the gas is getting to the fuel rail...it is spraying right where the line meets the rail.
And what is the vapor return line? I have one line going into the fuel rail more towards the front of the vehicle, and a vacuum line that is towards the rear. Where should that line be connected to? i may have connected it to the wrong spot..
Old 08-17-2005, 03:58 PM
jscarrozzo's Avatar
dumbass me....i did loosen the line, and never tightened it..
have one more fuel related question...where does the fuel return line go to. I think i have it right, I just want to make sure.
All is well for now....it's alive!
bigjstang
08-25-2021 12:41 AM
Colington
03-08-2020 09:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
smiley52
07-11-2015 05:16 AM
nick b
07-11-2015 04:38 AM
Quick Reply: help! fuel leak after reassembling from head gasket job
