Hella horns install
Old 06-15-2004, 08:53 PM
3.4v6's Avatar
Hella horns install
i got my hella horns today and was wondering if you can just plug them in or do i have to use the relay that came with the horns.
anyone?
Old 06-15-2004, 09:07 PM
914runner's Avatar
I thought that you used the hella relay way of wiring them up but don't quote me on that.
Old 06-15-2004, 09:13 PM
3.4v6's Avatar
the directions say to use their diagram, but i was wondering if they are like the freeway blaster horns, so all you have to do is plug them in and thats it.
Old 06-15-2004, 09:14 PM
914runner's Avatar
did you try searching? I think this has been covered before.
Old 06-15-2004, 09:29 PM
Bob_98SR5's Avatar
3.4,
Which Hella horns? If the Supertones, I installed them w/o the relay and I've never had a problem. Just a matter of splicing wires.
If the air horns, no clue. As the previous poster said, a search would probably answer your question.
Bob
Old 06-15-2004, 10:48 PM
Brendan's Avatar
air horns would need a relay
Old 06-15-2004, 11:19 PM
Tacoma Dude's Avatar
technically you wouldn't need to use the relay but you may find yourself in need of replacing a fuse...
Old 06-16-2004, 12:26 AM
jimbo74's Avatar
your horn system actually has its own relay... i have installed air horns in several different cars and the stock system was fine
Old 06-16-2004, 12:39 AM
Bigkahuna808's Avatar
I installed my airhorns with the supplied relay. I figure they must have given it to me for a reason. But it also came with a horn button, which I didn't use. So you figure, that the kit can be installed on cars that never had horns. Thats prob, why it came with the relay and the horn button. But I decied to use the relay.
Old 07-01-2004, 10:10 AM
nags's Avatar
How do you install the supertones? my stock horns have one little plug thing and the hallas have two prongs
Old 07-01-2004, 10:34 AM
00Runner's Avatar
If they are the Freeway Blasters then you don't need a relay. One prong to power (same as stock) and the other prong to ground (the bolt that holds the horn on the body.
Old 07-01-2004, 10:48 AM
Jason B's Avatar
You don't need the relay if you get rid of the stock horns. Whether they are air horns or just regular horns, you use the existing wiring.
Now, you would ONLY need a relay if you wanted to keep your existing horns where they are, and add a 2nd set, for a total of 4 horns. Most don't do this.
More info on my site, look for the air horn write-up.
Old 07-01-2004, 10:52 AM
rimpainter.com's Avatar
What Jason said. Plus, you can leave one of your "Roadrunner" stock horns in place on top of the new horns (as a wimpy back up).
Old 07-01-2004, 11:18 AM
nags's Avatar
alright, I'm havin' probs here.. do you just cut off that stock harness and splice those 2 wires together? and then ground the other end?
Old 07-01-2004, 12:06 PM
nags's Avatar
got one horn installed.. dont even know if its working right... so I just threw everything back together.. guess I'll wait till I get a specific answer how to do it
Old 07-01-2004, 04:01 PM
3.4v6's Avatar
plug the wire from the stock horn onto 1 prong and just ground the other prong.
Old 07-01-2004, 05:17 PM
Brendan's Avatar
i think he's got two horns though. should he split the positive wire for each horn?
Old 07-01-2004, 05:41 PM
Guest
4RUNR's Avatar
Woa! Air horns draw 20amps+.
A 14 gauge wire that loops through the steering wheel is long enough to be grossly undersized.
Old 07-01-2004, 09:57 PM
3.4v6's Avatar
i have 2 horns also ... there will be 2 positive wires ... one for each horn, then just ground each horn
Old 07-01-2004, 09:59 PM
nags's Avatar
that first harness has 2 positives? and the second horn doesnt? hmmm
Quick Reply: Hella horns install
