Hella Driving light wiring problem
Old 02-07-2004, 05:29 PM
obxfishn's Avatar
I have 2 hella 500's on the front and I DO NOT want them to be wired in to activate with my high beams I want them on a separate switch. I have a relay with 4 prongs on it. One is for the ground, one goes to the lights, one is power, and the last one is what I ahve a question about. How do I wire up driving lights through a relay from a 3 prong switch to operate my new Hella's separately from my high beams. I am looking to have a totally separate set up so that I can turn on my driving lights when I want to via a switch on my dash. Any help is indeed appreciated. Thanks
Old 02-07-2004, 05:39 PM
Billf6531
Guest
Posts: n/a
Wire the last prong to a wire that is hot only when the ignition is on. That way you can't accidently leave the lights on.
Old 02-07-2004, 05:44 PM
runnerboy97's Avatar
either that, or just tap it into the main power wire, and just check to make sure you dont leave the lights on.
Old 02-07-2004, 05:55 PM
A 4 post relay has 2 sides, a switching side and a load side.
Load Side:
1pin connected to the batery +
1 pin connected to the consumer (lights)
Switch side:
1 pin signal wire comming from switch in dash
1 pin going to ground
normally (not always) the relay may have the diagram on the side of the relay case, and the connections will be numberd. Look at the actual pins, there may be numbers next to them that coorespond to the diagram. This will tell you what side is switching side and what is the load side.
Check this out.......
http://electronics.howstuffworks.com/relay.htm
Id go for a 2 prong switch to make life easier!
Good Luck
John
Old 02-07-2004, 06:01 PM
waskillywabbit's Avatar
Hella 500
I have a simple write-up on how I installed my Hella 500s just like you are talking about. It is on my website under the write-ups section.
Old 02-07-2004, 06:06 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Look in the Tech section here as well.
I have info in there on how to wire up the factory Toyota switch with Hella 500 lamps.
I have mine wired up to come on at any time.
Old 02-07-2004, 08:19 PM
obxfishn's Avatar
If i'm understanding this correctly the 3 prong switch has a power tap into the fuse panel either always hot or only hot when the key is on, and the relay is connected to the battery. Am I understanding this right: the switch has a separate power source and so does the relay?
Old 02-07-2004, 08:26 PM
Staff
Corey's Avatar
That is correct.
The power source for the switch only has to be a trickle, it's what energizes the relay.
I have all three sets of my light switches tied in together, and it goes to one fused outlet on my underhood fuse box I wired in.
https://www.yotatech.com/~corey/tech...box/mod39e.jpg
Old 02-07-2004, 08:30 PM
obxfishn's Avatar
Originally posted by Corey
That is correct.
Excellent!! As always the crew pulls through for me. Thank you again and I will send pics when I am finished.
Old 02-07-2004, 08:39 PM
Staff
Corey's Avatar
Old 02-08-2004, 07:55 AM
goldtaco9's Avatar
Corey,
Where did you get that fuse block?
Thanks,
Mike
Old 02-08-2004, 08:07 AM
Staff
Corey's Avatar
Mike, I got it at my local Schuck's Auto Parts store for around $10 or so.
But you can also get them from Waytek.
Mine is a 6 gang block, with no ground.
Old 02-08-2004, 08:10 AM
goldtaco9's Avatar
Thanks. That's terrific. All I ever see around here are fuse blocks that do not have a common power source, basically just fuse holders. That unit is much neater.
Thanks again.
Mike
Old 02-08-2004, 08:24 AM
Staff
Corey's Avatar
Yep, that big bolt goes right to your battery with a wire, and an inline fuse of course.
All the stuff I have connected to it have their own grounds, so no need for me to have a grounding source on the unit itself.
This is really a very simple mod indeed.
More info on it can be found here.
gillesdetrail
11-19-2019 12:56 PM
ibayne
06-26-2015 06:30 AM
ItsAtoyotaLIFE
06-21-2015 11:45 AM
infinityisfive
06-16-2015 06:51 PM
LSUMatt1514
06-26-2002 05:03 AM
Quick Reply: Hella Driving light wiring problem
