| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Head Gasket?
#2 (permalink) |
i would suspect the easy things first.
Plugs, spark plug wires, coil.
__________________
2000 4Runner v6 sr5 4x4 5spd: Turbo'ed 99 4Runner v6 Sr5 4x4 5spd: Saw's / OME combo TrueTrac rear 98 4Runner V6 Sr5 4x4 5spd E-locker: Saws / OME combo... EEZI AWN Roof Tent 1.4m 97 4Runner V6 Sr5 4x4 Auto: Saws / OME combo TrueTrac rear 2003 Landcruiser 285 BFG At's and outback roofrack My Baja Trailer Build: http://forum.ih8mud.com/showthread.php?t=179520 http://community.webshots.com/user/bajaroadtrain |
#3 (permalink) | ||
If you suspect the head gasket, do a compression test, 2 cyl next to eachother that are considerably less then the rest would indicate a failing head gasket. That being said...I agree with j-man, check the easy stuff first.
__________________
Quote:
Quote:
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting DD: 94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 200k on the clock Project: 91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 219k on the clock. It's becoming an addiction. |
#4 (permalink) |
Its a Toyota engine with 90k on the clock? its just breaking in!
![]() The probablilty of it being a blown head is pretty slim. Unless you overheated the engine, or was running it really hard, I wouldn't really think twice. You could do a compression test yourself and if there are 2 cylinders next to eachother that are low, it may be a sign of a blown head. Another often symptom is oil in the water, or water in the oil, so just check that. (Your oil would look white).
__________________
1996 4x4 3.4L 4Runner on 35's - 6" of lift, MTR's, E-locked, ARB Tacoma Bumper, Sliders and a cut off tail pipe. 1966 FJ40 - SOA with stock springs, stock 1F motor, and a smelly tailpipe. WTB: 265/75/R16 AT's |
#5 (permalink) |
Yea, I believe it is the coil myself. Ill probably replace it and see if it solves the problem. Ill keep the thread informed on the progress.
#6 (permalink) | |||
Quote:
__________________
Quote:
#7 (permalink) | |||
Quote:
__________________
Quote:
#8 (permalink) |
Could be a bad fuel injector.
Could be a bad spark plug. Could be a bad spark plug wire PROBABLY NOT the coil. One coil fires 2 cylinders. If a coil goes, BOTH cylinders will not fire. Could be a intake manifold leak. The "mechanic" you took it to is not much of a mechanic. First thing, replace the plugs. Swap coil WIRES and see if problems follows the wires.
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#9 (permalink) |
Ok so it still has a mis-fire on cylinder 4. (After swapping the coil) Next I guess I will replace the plugs. (Plug appears to be ok)
| Tags |
| 22re, 3vze, gasket, head, intake, leak, manifold, test |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22RE Head & head gasket replacement tips????!! | HelliphinoN8 | 86-95 Trucks & 4Runners | 6 | 03-14-2008 05:17 PM |
| Looking for opinions 22r Head/head gasket swap what bottom end? | TurboVWguy | 86-95 Trucks & 4Runners | 10 | 11-02-2007 05:08 PM |
| Cracked Head or Blown Head Gasket? | StevenR | Maintenance & Repair Archives | 5 | 06-14-2005 09:49 AM |
| head gasket? | John79 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-26-2005 05:03 AM |
| Replaced Head Gasket, but not Head Bolts -- How bad is this? | The Rusty Gear | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 09-13-2004 07:03 AM |
