green brake fluid?
Old Feb 12, 2005 | 10:24 AM
mike_d's Avatar
green brake fluid?
this morning i decided to bleed my brakes because they've been feeling squishy (and it feels like i have no back brakes). the fluid that came out was green? i've never seen that before. does anyone know if that's bad and what would cause that? also, the beeding didn't improve the feel of the brakes or the fact that it feels like i'm only stopping with the front. i bled the LSPV and made sure that it was adjusted right since i installed add-a-leafs, and that's all ok. does anyone have any ideas on other things to look at? (pads and shoes are still good)
thanks!
Old Feb 12, 2005 | 10:28 AM
jimbo74's Avatar
there are differnt colors of brake fluid... i have some ate racing brake fluid that is called super blue.....
if it was normal, its highly possible that it absorbed jsut basic crap from the air, as brake fluid does this a lot, thats why it does ocassionally need to be flushed
Old Feb 12, 2005 | 02:03 PM
Nic's Avatar
Nic
Your brake master cylinder may be going out.
Old Feb 12, 2005 | 03:43 PM
backyard_motorsports's Avatar
i have a ford ranger, and the same prob happened to it, and the master cylinder went out of it, as for the fluid colors is concern, someone might have put a racing fluid in it???? who knows
Old Feb 12, 2005 | 08:24 PM
TechWrench's Avatar
thanks!
Are you sure the rear drum brakes are adjusted correctly? If not, that would give you a 'soft' pedal.
Old Feb 12, 2005 | 08:41 PM
wrenchmonster's Avatar
How's your vacuum source to the booster? Booster itself okay? Loosing any fluid?
-Wrench
jasonty
41
Dec 23, 2018 01:00 PM
mussy01
Dec 13, 2016 08:20 PM
fountain
Dec 31, 2015 06:08 AM
JHalcyonM
Aug 4, 2015 01:19 PM
Johntom240
7
Jul 13, 2015 12:18 AM
