YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 11-14-2007, 05:38 AM   #1 (permalink)
Personal Sales Rating: (0)
oxfordethan's Avatar
gear selector switch
A friend of mine has a '98 2wd limited 4runner. The button on the gear selector will not press in and allow the transmission to be changed from park. Does anyone know what the cause of this might be and how to fix it?
oxfordethan is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 11-14-2007, 06:31 AM   #2 (permalink)
mikes19984x4's Avatar
Quote:
supposedly you can take off some of the plastic and all around the shifter and there's something that you can stick your key in and it will "unlock" the shifter...not 100% sure about this, but it happened to my buddy's 2000 limited 2wd 4runner while he was launching a boat, and he said he did something like this...
__________________
1998 4Runner SR5 4x4
3.4 w/5-speed & E-Locker
Deckplate & ISR mod w/K&N, 2.5-inch Exhaust w/40-Series Flowmaster
Centerforce Clutch
Bilstien Shocks, 265/75/16 Buckshot Mudders
Sylvania Silverstars, Hella 500s on front bumper (no longer), Orange Gauge Lights, JVC Arsenal Head Unit, Pioneer REV-Series Speakers
More mods to come...
mikes19984x4 is offline
Old 11-14-2007, 07:17 AM   #3 (permalink)
eric-the-red's Avatar
The shift lock has an electric solenoid that is controlled by the brake light circuit. First check the brake lights, if they're not working then either the STOP fuse has gone or the switch on the pedal is bad. If the lights are working then the solenoid may have gone bad. You should be able to shift by lifting the samll black plastic plug at the front of the shifter, and pushing something in there to release the shifter. Like Mike said a key usually works.
eric-the-red is offline
Old 11-14-2007, 07:49 AM   #4 (permalink)
Rock Slide's Avatar
^ x2.
If one of your brake light bulbs is out or the fuse to them is blown, the vehicle will not shift out of park when the button on the gear selector is depressed. This is a safety feature installed by toyota.
Until either the fuse is replaced or the bulb is replaced (which ever one is the problem), you'll have to get a screwdriver, pry open the clip next to the gear selector and manually unlock the transmission. (I've had to do this before on a friend's 4Runner before.)
Once the brake light issue is fixed, you will be able to shift the gear selector out of park like normal.
A friend of mine had this happen on his '98. Come to find out, it was faulty wiring on the trailer that caused his brake lights to short out, thus blowing the fuse. This in turn would not let him shift out of park.
Talk about a strict safety feature...
__________________
2002 4Runner Sport 4WD
My 4Runner Profile
Accessories: SS 7.1 Lift Kit, WabFab 1" BL, Modified & Color-matched TJM T-15, Stubb Sliders, FX/TSX HID Projector Retrofit, Tundra Brakes, Hilux Surf Field Monitor, TRD Ivan Stewart Wheels, Yoko Geolanders 265/75s, WeatherTechs, Pioneer HU, LED Tail Lights, JBL Speakers
Mods: Disabled DRLs, Disabled Keyless Entry Chirp, AndyMod 2.0, Fog Light Mod, Air Elbow Mod, Rear Diff Breather Mod
Rock Slide is offline
Old 11-14-2007, 07:53 AM   #5 (permalink)
GOH10 Runner's Avatar
Send a message via AIM to GOH10 Runner
Quote:
x3
Im betting its the switch on the brake pedal. If it is its a pretty easy job to do.
__________________
Aaron
03 Silver Limited 4WD w/ XREAS
SOLD: 99 Black 4Runner SR5 4WD aka TJ
SOLD: 98 Anthracite Limited 4WD
98 Land Cruiser
GOH10 Runner is offline
Old 11-14-2007, 01:25 PM   #6 (permalink)
98runner210's Avatar
+1 on checking the fuses. I hooked a trailer up and apparently the trailer wiring had a short killing my fuse for my brake lights. I didn't know and couldn't figure out why I couldn't get out of park. I just swapped the fuse for the stereo untill i could get a new fuse.
__________________
'98 4Runner Limited White w/ silver flares
98runner210 is offline
Old 11-15-2007, 04:29 AM   #7 (permalink)
Threadstarter [OP]
thanks for all of the suggestions and info.
Yotatech
4WD Truck
Paid Advertisement
Tags
1994, 2002, 2004, 4runner, brake, break, controlled, electric, gear, pedal, selector, shift, shifter, switch, toyota, tundra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Manual tranny 4wd selector question wheels_CA 95.5-2004 Tacomas & 96-2002 4Runners 14 04-25-2007 07:48 AM
Diff/transfer case/tranny gear lube capacities? (Amsoil synthetic switch) CoedNaked 86-95 Trucks & 4Runners 1 07-14-2006 06:41 AM
Vent selector switch not working Tanto 95.5-2004 Tacomas & 96-2002 4Runners 15 06-26-2006 07:48 AM
Dead Starter/broken Xfer Selector FormulaTwo 95.5-2004 Tacomas & 96-2002 4Runners 0 07-05-2004 07:52 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
