gear ration
gear ration
I put the front differential out of a 1999 toyota 4runner limited in my 1988 toyota 4runner. my 88 is 410 gears and the 99 diff must not be because i have binding when in 4 wheel drive anyone who what gear ration a 99 4runner limited had for ratio? the front diff has Pink dots of paint on it and R-37 tag. any help would be appreciated. thanks.
gear ratio
I did a 3.4 swap with auto tranny and transfer case which has front drive shaft on opposite sides so had to mount front diff out of 99 in 88. Took some ingenuity but it wasnt that bad. I also had to blend the front CV axles with 99 on inside and 88 on outside that worked really slick and was quite easy. Mounting the diff wasnt that bad either. Truck has 3 inch suspension lift otherwise it wouldnt have worked. It all turned out beautiful except for the different ratios. I now have a set of 4.30 gears ordered for the rear of the 88 and that should solve everything!! I hope!
Shaun Crystal Gomban
07-30-2015 10:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
