Gear indicator and reverse lights not working
Old Feb 9, 2005 | 02:29 PM
chrome_ashes's Avatar
Question Gear indicator and reverse lights not working
I've got a '98 Tacoma 2wd automatic. The gear indicator on the dash doesn't work and neither do the reverse lights. Both were like this when I got the truck, so I don't know if they started at the same time, but they seem related to me.
Any ideas what could cause this??
Old Feb 9, 2005 | 06:24 PM
wrenchmonster's Avatar
Sounds like a PRNDL switch aka transmission range switch. I'm not at all familiar with your yota, but this switch is probably on the side of your transmission. Technically speaking, it could be anywhere in line with the movement of the shifter linkage.
No obd II codes set?
-Wrench
Old Feb 10, 2005 | 07:44 AM
You know...I haven't had the codes checked yet, but it hasn't set the cel yet. I guess that would be a good start.
I looked around a bit for the PRNDL switch, but couldn't find it. I've got the steering column housing off and there's no sign of it there. I looked on the side of the transmission where the linkage goes, but it's not there either. There is one sensor on that side of the tranny; it's farther back, toward the driveshaft, and looks like maybe a two-wire connector.
I suppose I should do some more looking...
Aleeex_u
Jun 5, 2016 06:52 PM
Ichneumon
Sep 27, 2015 04:21 PM
camdenbuck
Jul 7, 2015 07:33 AM
gog1968
Jun 22, 2015 05:55 AM
streetuner15
Jun 18, 2015 10:59 PM
