Gear/Bearing noise
Old 12-10-2007, 04:50 PM
carlj75's Avatar
Gear/Bearing noise
I have a '00 V6 4x4 Tacoma extended cab with a 5 speed manual tranny. The truck has about 180k miles on it. This noise started out of the blue about 4 days ago. It happens in any gear when I let off the gas and coast. The noise goes away when I am on the gas, in neutral, or press on the clutch pedal. It also happens at any speed. The noise sounds like a slight grinding or whine and sounds like it is coming from the rear of the truck. I replaced all of the fluids about 2 months ago. Any help would be great.
Old 12-11-2007, 12:23 PM
carlj75's Avatar
Has anybody else had a noise like this before. I have tried searching, but couldn't find anything related.
Old 12-11-2007, 12:29 PM
andtheman1988's Avatar
did you check your carrier bearing?
Old 12-12-2007, 12:34 AM
carlj75's Avatar
Is there a way to check it? Or do I just have to replace it and hope the noise goes away?
zytra
01-24-2019 03:16 PM
Davebarbier
11-03-2015 03:28 PM
zombie_barbarossa
10-02-2015 10:54 PM
JPV
09-28-2015 03:15 PM
Quick Reply: Gear/Bearing noise
