| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Fuel Type?
#2 (permalink) |
I use Tier 1 (top tier) fuels only. They contain far higher amounts of deposit control additives than other gasolines.
The additives are the only difference. |
#3 (permalink) |
i put nothing less than mid grade in my truck dosnt really matter where i get it as long as its not citgo my truck always runs funny even on their super
#4 (permalink) |
Top tier gas here too. I've been running 85 with no problems lately but every few tankfuls I run 87 for good measure.
__________________
'99 4Runner Highlander 4wd E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub |
#6 (permalink) |
My runner pings on 87, so I have to use 89. I need to clean the MAF and see if that helps...
__________________
2000 Silver 4runner :Highlander Edition: - Tundra TRD Coils/Blue Tokico Struts w/spacer- Downey Coils/N86 Shocks - Front Dif. Drop - Rear Dif. Breather - E-Brake Extension - Tundra Calipers/Rotors - Akebono Ceramic Pads - Goodrich SS Brake Lines - LX450 Wheels w/ 265/75/16 BFG A/T KO's and Full Size Spare - TRD Exhaust - Deckplate w/ Trueflow - Hayden Tranny Cooler - JAOS Rear Spoiler - Sport Skid - '01 Tails - Clear Corners/Bumper Lights - Leather Seats - Alpine CD player |
#7 (permalink) |
From AAA:
Gasoline Octane Some motorists are under the false impression that premium-grade gasoline gives their car more power, better fuel economy, or a longer life. Some even think they are giving their car a "treat" by filling up with an occasional tank of premium. The reality is that using premium fuel in a vehicle that was designed to run on regular is a waste of money. Premium fuel is needed by a handful of vehicles with high-performance engines. These vehicles require premium fuel to prevent pinging and its associated loss of power. Combustion chamber deposits in some older engines may cause pinging. In many cases, the least expensive fix is to use a higher grade of gasoline rather than to have the deposits mechanically removed. Federal regulations require that all fuels sold in the United States contain detergents to prevent the build-up of deposits in the engine's combustion chamber. Several name-brand gasoline marketers promote their own fuel additive packages that have detergents formulated to clean up deposits. With few exceptions, their premium fuel contains the same additives as their other grades of fuel, including regular. Therefore, additives marketed to remove deposits, clean fuel injectors, and improve performance are generally viewed as a waste of money.
__________________
00 4Runner, TRD Headers & Exhaust, Deckplate, Amsoil |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 90 toy fuel pump ques. and fuel guage | npreo1 | Offroad Tech | 1 | 05-23-2007 11:24 AM |
| 3.4 Fuel pressure drain back. Fuel sys? | kleinqpro | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 04-30-2007 07:47 PM |
| 95 Taco fuel injector, fuel trim questions | OtherHand | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 01-04-2007 09:49 AM |
| Fuel line? Fuel pump? Fuel injector? | MikeKaduce | 86-95 Trucks & 4Runners | 3 | 11-06-2006 07:21 PM |
| rear end fluid type? (middle of locker install look inside for type) | FOCUSHERE | 84-85 Trucks & 4Runners | 3 | 10-21-2006 05:22 PM |
