Fuel Level Guage
Old Feb 14, 2005 | 04:10 PM
Sherpa's Avatar
Fuel Level Guage
A colleague asked me if I would be replacing the fuel level sending unit when I replace the fuel pump. He said it is about a $17 part, but didn't know if it was a problem in Toyotas like it is in some vehicle types.
Is this something I should replace while I am in there?
Thanks,
-Scott
Old Feb 14, 2005 | 04:21 PM
Bob_98SR5's Avatar
scott,
are you replacing your fuel pump on your 97? and are you asking if the fuel sending level unit needs replacing? and are you asking if there are other parts that need replacing besides the FSLU? just want to make sure b/f answering the question. i might be able to pull up a diagram for you but it will be out of my 98 which should be identical to your 97.
bob
Old Feb 14, 2005 | 04:58 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Why are you replacing the fuel pump on a '97? Preventive maintenance? As far as the sending unit, I've seen 1 or 2 posts over the years about sending units going bad (not including the TSB on the 3rd gens with the out-of-cal units). But if it's $17 like your buddy said (I've heard they're about $140 from the stealership), then go for it!
Old Feb 14, 2005 | 04:59 PM
Sherpa's Avatar
Hi Bob,
The idea to replace the float that measures how much fuel you have in your tank and sends that information to the dashboard instrument gauge was brought up today. Since I am already in the fuel tank, would it be a good idea to replace that float, or whatever the device is that measures fuel level.
Thanks for your interest!
Old Feb 14, 2005 | 05:01 PM
Bob_98SR5's Avatar
sherpa,
i dont know if those things need to be replaced w/ the fuel pump, but if you'd like, ill email you a diagram of said area send me your email addy to bobkim@4runners.org
bob
Old Feb 14, 2005 | 05:11 PM
Sherpa's Avatar
Thanks guys.
I am installing the URD Fuel Upgrade Kit. Part of the kit is a higher capacity fuel pump.
Bob, thanks for the offer. I think I'll leave it alone.
Old Jul 14, 2011 | 11:12 AM
johnnyoflenory's Avatar
fuel gage on 1985 toyo pickup not reading need help what to do
yourrealdad
Jul 29, 2015 11:08 AM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
shisha1999
Jul 13, 2015 11:09 PM
akaphilly
Jul 9, 2015 02:18 PM
