Front Turn Signal Power Question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-03-2003, 09:46 AM   #1 (permalink)
LSUMatt1514's Avatar
Send a message via AIM to LSUMatt1514
I've got a couple questions about the front turn signals on the 3rd gen....
1. Which wire at the bulb is the positive 12 volt wire?
2. Do the turn signals blink because a relay is supplying the bulb 12 volts, then zero, 12 volts, then zero, etc?
I haven't decided about installing the VW sidemarkers yet, but I found an alternative today that I might go with. Just want to clear up these power questions before starting the install.
Thanks guys. Later.
Matt
__________________
01' SR5 Sport Edition
Performance: Deck Plate w/ Amsoil Filter, ISR Mod, Dynomax Super Turbo w/ Pacesetter Tip
Exterior: Manik Brush Guard, Piaa 1000X, Piaa 540, OEM Skid Plate, Custom Sidemarkers, Clear Corners/Bumpers, H/L Alenzas, Thule Lappland Cargo Basket, Reverse Lamps, Silverstars
Interior: Stereo System, Dakota Digital Gauges, Coleman Inverter, Speedhut Gauges
http://community.webshots.com/user/phi1514
LSUMatt1514 is offline
Old 05-03-2003, 05:03 PM   #2 (permalink)
WT
WT's Avatar
Not sure but a Meter or test light will help for sure. Most times its a relay that is used to make the voltages go +12V and -12V
WT is offline
Old 05-03-2003, 05:59 PM   #3 (permalink)
rjm
turn signals
usually the ground wire is black or black and another color ( black with a white stripe,etc)
rjm is offline
Old 10-14-2004, 11:07 AM   #4 (permalink)
timber725's Avatar
Quote:
This will explain everything:
http://www.howstuffworks.com/turn-signal.htm
But it is NOT a relay. It's a simple unit called a Thermal flasher. The article explains everything clearly.
__________________
'03 4Runner LTD 4WD V8
Revtek 3" Lift w/ NE Spacers | 285-75R16 Firestone Destination MT | 16x8 American Racing AR-23 | BVG Evolution Bike Rack | BVG Adventure Rack w/ Yak Fairing | Husky Liners | Tacoma Skid Plate
| Sylvania Silverstars
timber725 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Introduction & Brake/turn signal question. WYScott General Vehicle Related Topics (Non Year Related) 0 01-21-2007 12:19 PM
Front turn signal problem geoduke 86-95 Trucks & 4Runners 10 12-10-2006 11:53 PM
90-95 truck/runner front turn signal lamps Arnold The Classifieds GraveYard 1 02-25-2006 08:54 AM
LED Turn Signal Question ATP4984 95.5-2004 Tacomas & 96-2002 4Runners 6 11-09-2004 04:06 AM
Turn signal/Brake light wiring question pfdaxe 95.5-2004 Tacomas & 96-2002 4Runners 10 07-30-2004 01:05 PM
2009 InternetBrands, Inc.
