Front Suspension Noise... help!
Old 04-21-2004, 02:20 PM
SBeckner80's Avatar
Allright, no one seems to know what this is, so I'll ask you guys...
My gen 2 4runner suspension makes this noise... it's like a really loud short burst "creeking" noise when I am both turning AND the suspension is flexing, i.e. when I going over a curb. It started after I had the mechanic replace the cv boots I think.
I can reproduce it reliably by cranking the wheels all the way to one side and popping the clutch real fast, then it wont do it again unless I turn the wheels the other way. However, the wheels dont have to be turned all the way, but to reproduce it reliably I turn them all the way.
Any other ideas on what this might be? To be more specific about the noise... it's a loud "creeking" noise, but violent enough that is sounds almost like a popping noise at first. I feel it through the steering wheel.
Old 04-21-2004, 02:38 PM
SBeckner80's Avatar
bump!
Old 04-21-2004, 03:20 PM
fooddude's Avatar
Put some grease on your steering stops. I had the same problem and same with probably most people on this board. The rubber bushing wears out and metal grinds on metal= that horrible sound.
Old 04-21-2004, 03:51 PM
SBeckner80's Avatar
Ohhh... I noticed that the steering stops were warn down to the metal... but would that make the noise even if I'm turned half of the maximum?
Old 04-21-2004, 06:17 PM
fooddude's Avatar
yes it did on mine. just try it anyways it takes all of 2 seconds. Not like theres much to lose.
Old 04-21-2004, 08:14 PM
nofilter's Avatar
i think it's the torsion bars. happens on mine. also used to happen on my old mazda 2wd (torsion bars, too).
Old 04-26-2004, 11:50 AM
SBeckner80's Avatar
IT WORKED! Put some bearing grease on the steering stops (4 of them) and the noise is gone. Thanks!
09-04-2015 09:27 AM
Yotadawgjr
10
08-23-2015 10:51 AM
coffey50
07-28-2015 10:55 AM
andrewtexas123
07-23-2015 11:22 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Front Suspension Noise... help!
