Are front lower control arm bushings interchangeable (front/back)?
Old 01-20-2015, 01:59 PM
YM13's Avatar
They have different part numbers and as far as I could tell visually the only difference is the rear has a two rubber markers and the bushings facing the front have one solid rubber marker along the edge. That is the only distinguishing feature I could gather.
I'm asking because I asked a shop to press out the old ones and put in the new ones for me and instructed them to maintain the correct placement. They of course put the bushing that was supposed to be in the front on the back end of the control arm (on one of the control arms). Should I get them to press them back out and redo it? If they do press them back out won't it ruin the bushings since it will strain the rubber?
Can't catch one break from a shop around here.
Old 01-20-2015, 02:34 PM
YM13's Avatar
Didn't see this post on new posts so just trying to bump it on there...
Old 01-21-2015, 10:51 AM
YM13's Avatar
Going to call a dealership and see if they can offer any insight? Anybody know anything about this?
Old 01-25-2015, 01:53 PM
robb1887's Avatar
I haven't changed out my FCAB's yet so I cannot say with 100% certainty but I could not see what the difference in the two could be. I would take it back to the shop though and see if they will swap it without damaging them. They should have metal sleeves on the OD that the shop "should" match to one of their press dies that should not damage the new ones but that's a respectable shop.
Old 01-26-2015, 11:32 AM
YM13's Avatar
Thanks robb, I spoke to a service manager at Toyota and he told me to just leave them as is as it was his opinion I would not run into any issues. I did not want to take the chance of them lying to me that they pressed them back out right and further aggravating the issue or making it worse. Now to find someone that will do a decent alignment...
Old 01-26-2015, 03:13 PM
robb1887's Avatar
Just a learning experience I had. I took my truck to get aligned and they did it and I paid and left. Got home to file the paperwork and realized they charged me for a 4-wheel alignment. Nothing is adjustable in our rear, so they should only be doing a "front end" alignment and charging accordingly
lledwod
08-30-2016 01:03 PM
09-04-2015 09:27 AM
88sasturbotoy
08-11-2015 01:56 AM
1994toyota
07-17-2015 03:03 AM
ptb12
07-05-2015 01:49 PM
Quick Reply: Are front lower control arm bushings interchangeable (front/back)?
