Front end lift
Old 01-25-2004, 04:09 PM
Front end lift
I'm sure that this has been done to death, but I cranked my torsion bars and put OME 55mm springs in the rear, but the front is still a little low. Any suggestions on how to equal it up? Should I try to give the T-Bars a little more, I think that they are to the limit? Perhaps 1"body lift, but can that be done only to the front and not the back??? Help me out here!!!
Old 01-25-2004, 05:34 PM
beachtaco's Avatar
nope. that's pretty much it. you can wait for the rear springs to sag. cranking the t-bars to 1.5 is the max. you can try to setup a progressive body lift. it's all custom but i've read it done to desert prerunners. basically, you take a bl kit and trim the pucks done from what you want. i've since them from 3" in the front to the 1" in the front.
Old 01-26-2004, 05:26 PM
See, I am wondering how all these folks on here did such a wonderful job leveling theirs out? mine just happened to end up ass end up (no pun intended). I kinda just wanna make the front about .5 " taller.............
Old 01-26-2004, 07:05 PM
Cebby's Avatar
What about a ball joint spacer? I remember reading about that over on ODW I think.
Old 01-27-2004, 07:35 AM
beachtaco's Avatar
the idea behind the spacer is to reduce how much you crank the t-bars for a better ride. i think the most you can crank the t-bars is a little over 1.5" before it hits the upper bump stop.
Old 01-27-2004, 09:27 AM
Alright, I got a bit more out of the T-bars, so now I guess it is time for a sway away bar, feels a little loose, but that is ok....You think these ball joint spacers would give you a more stable ride? Or is that just the evil of having a higher truck?
Flying91
45
04-11-2024 04:39 PM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
akaphilly
07-09-2015 02:18 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Front end lift
