Foglights won't work!
Hey guys, I got a question, I noticed one of my fogs was out and I went to change it, and it still didn't work. Is it possible that the fuse could be blown?? I'm not sure what to do, because one still works. They are Hella fogs... the one's made to fit the 00 4Runner's.
Thanks!
~Mike
Thanks!
~Mike
Burnt out bulb?
Is your bulb burned out? It wouldn't be the fuse because then both would go out. I have the Hella's too and have had some problems with them too. Check to see the the end of the H3 bulb is far enough in the rubber shoe so that it connects metal to metal. The only other ideas I have are that a wire is severed or rain has oxidized the female connector end in which caseyo cou just sand it down a bit.
Zach
Zach
ashersullivan88yota
01-18-2022 05:37 PM
