| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Failed Smog Check
__________________
1998 4Runner SR5 - 16" Remington Wide Brute AW Tires, K&N Airfilter, Deckplate Mod, ISR Mod, WAAG Donkey Killer Bars up front, WAAG Tail Light protectors in the rear, Kenwood MPV-622 Head Unit, Lightning Audio B400 Amp and 10" sub. |
#2 (permalink) |
make sure your truck is good and hot before the test. The exhaust has to have a chance to warm up the cat to operating temperature. If it was hot during the test then you might want to close the deckplate. If that doesn't work you might start checking o2 sensors and cleaning the maf.
__________________
We are the people bred, raised and nurtured to maturation to live life in the pursuit of acquiring status-ensuring product in a never ending pilgrimage to find value in ourselves through the indulgence of materialism...gotta love it oh yea, 98 4x4 ltd for sale |
#3 (permalink) |
MAF should be clean. Cleaned it about 500 miles ago. I just don't want to waste the free smog test by closing the deckplate, if it is an O2 sensor.
__________________
#4 (permalink) |
If you do fail again, go to a "test only" center and usually you can find one that offers "pass or don't pay". That's the only way I do it nowadays.
Good luck.
__________________
1994 4x4 4Runner 3.0L |
#5 (permalink) |
Rhew,
I had to go to a Smog Only station. The ones out here only let you try to pass smog 2 times I guess. I guess that I will try it again with the deckplate closed. Crosses his fingers!!!
__________________
#6 (permalink) |
Good luck, though mine passed at a St. Louis smog check w/deckplate open, no problem.....once I got the obdII fixed to connect with their computer.
__________________
My rides: '96 4Runner SR5 4x4, manual. Deckplate, ISR, extended rear diff breather mods, flipped receiver hitch, power antenna switch, Garage door opener switch in dash, Kill switch somewhere in there, Thule playpen, system 1.2 installed without any swear words even when my kid walked off with my tools........ |
#7 (permalink) |
Nice bike Habanero,
Not too sure what you mean in the thread about the ODB scanner though.
__________________
#8 (permalink) |
Keep the engine running while you wait. The cats have to be hot to work properly. I passed a CA smog test with the elbow removed so I wouldn't worry about the deckplate being open.
#9 (permalink) |
When I was going to sell my Runner, I almost failed smog... This is with a 6 month old 02 sensor, spark plugs, fuel filter, MAF cleaned, and new air filter. I also have the ISR and deckplate. I barely passed the NO section... Four months later, I had to do my bi-annual smog... Two days before, I did a seafoam treatment and I passed the smog with flying colors on all the measurements...
Might want to give seafoam a try. Also don't forget to drive around for awhile as others mentioned to heat up your cats.
__________________
2007 Tacoma Double Cab 4x4 TRD Sport 6speed
Pro Comp 6" - Bilstein 5100 front 18x9 Moto Metal 951B - 325/60/18 NTG Pro Comp Skid - Lund Grill Cover 17x10 Weld EVO Velociti 6 *soon |
#10 (permalink) |
Running high for NOx would indicate that it was running hot/lean so I don't think the deckplate or truck not being hot enough was your problem. My money would be either on the MAF or the front O2 sensor (although it could be a few other things, fuel injector, fuel filter, vacuum leak, converters, etc). What was your NO reading and what is the Cali limit for your vehicle?
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 02-06-2007 at 05:23 AM. |
#11 (permalink) |
Seafoam is awsome. I run it in my truck, boat, quad, snowmobile!
#12 (permalink) |
MTL - here is the NO info. Weird that it was even higher with the Deckplate closed.
1st time - Deckplate OPEN 15mph - 688 FAIL - CA Max 512 25mph - 686 Pass - CA Max 765 2nd time - Deckplate CLOSED 15mph - 787 FAIL - CA Max 512 25mph - 741 Pass - CA Max 765 Car was good and hot and left running before check. I thought that Seafoam will foul your plugs and your O2 Sensors??? Is there an EGR valve on the runners?
__________________
#13 (permalink) |
That is what I believed about seafoam and is the reason why I waited so long to do it. I actually had the bottle sitting at home for over 3 months before I bit the bullet and gave it a shot.
It worked great and my readings were alot lower than 4 months before. I also didn't change any parts on the vehicle. I'll try to dig up my past smog reports and give you exact numbers. Again it might not be your problem but it cleared up a good amount of crap from my vehicle.
__________________
#14 (permalink) | |
Quote:
Check for problems with the following: - Air injection system (MAF, O2 sensor, vacuum leak) - Combustion chamber deposits (this can include the plugs as well) - Dirty fuel injectors (injectors and fuel filter) I would go about solving it by: 1) Run 2 cans of Seafoam or BG44K, 1 in the gas tank and 1 through a vacuum line 2) Change your spark plugs if they are over 25k miles old 3) Change your fuel filter if it is more than 40k miles old 4) Clean your MAF with some electrical contact cleaner The Seafoam can cause alot of havoc if you put alot in at once before you've run a can through the gas tank first. Basically if you run it in a vacuum line right away it will tend to loosen all the deposits at once and you can have issues. The preferred method is to chip away at them a bit more slowly and then do a clean sweep on whatever remains at the end. Only after you do the seafoam should you go an replace all the other items (plugs, fuel filter, etc). Then retest and see how you stand.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 02-06-2007 at 05:42 PM. |
#15 (permalink) |
I heard an interesting theory from the Instructor that teaches Auto Technology at the College that I work for, as to why I might be failing Smog. He asked if I had added oversized tires or rims to my 4Runner. That I have done. I put 16" rims and larger tires on my beast. He said that leads to the engine working harder to achieve the speed at which they test the emissions, resulting in more emissions. DUH! I should have thought of that!!! He is going to take a look at my 4Runner on Wednesday. I will post some info after he has done some testing. Of course I do not have my stock rims and tires, BUT my wife has a 97 4Runner and I can swap the wheels if need be!
__________________
#16 (permalink) |
Ok the instructor tested my runner today, with bad results. He tried to get it to test smog running in low gear, but it still failed NOx. He said that the only way to get it to pass smog was to put on the original wheels and tires, have the computer re-programmed for the larger tires, or change the gearing. Damn that sux. I have no idea what this is going to cost me!!!
__________________
#17 (permalink) |
Have you followed any of the other suggestions? or just tested again?
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#18 (permalink) |
Everything has been cleaned/changed within the last 5000 miles. I did not try the Seafoam. Will that help lower my emmissions?
__________________
#19 (permalink) |
The answer is it might if you're running lean at all (which you are if you have high NOx). In fact you might try having a place do the full BG44K service for you since the BG is a bit more potent than seafoam and has been proven to work very well.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 02-15-2007 at 11:53 AM. |
#20 (permalink) |
Have you changed your oil before a smog check?
When I was a California resident that was the trick, make the sure the engine was at operating tempature with the oil changed. Never failed.
__________________
My Profile |
#21 (permalink) |
I passed smog barely, I was at the max for NOx at 15 miles per hour. To pass, I had to put my wife's stock rims on the rear. This is going to be a pain for future smog checks, but at least I am good for the next 2 years!!!
(_)3 Cheers!!
__________________
#22 (permalink) |
smog?? wth are you talking about? yeah there is smog everywhere around here... NOx testing? huh???
I searched but I can't find an explanation as to what this "SMOG" is edit: NM sorry forgot I'm in MI... ![]() but yeah, it'd be nice if we even had some regulations
__________________
Andrew J W = WJwerdnA '99 4Runner SR5 - Pioneer MP3/IPod w/Infinity all around - lifted 2.5-3in susp. - 33's to fill the gap - sliders - ISR & Deckplate, yada yada - Satoshi - AIM:wjwerdna YotaTech Profile Custom Bumper Link for sale: ??? Nothing? |
#23 (permalink) |
Michigan sounds alot like up here in Canada too.
.....so what is this smog inspection anyway?
__________________
#24 (permalink) |
a pass is all that matters, how often do you have to get tested
__________________
2006 Tacoma 4x4 TRD Sport with 20's and 285 Goodyear Furtura's and 2 inch cornfed lift 2002 Tacoma Extra Cab V6 (SOLD) |
#25 (permalink) |
The Smog Inspection measures emissions and has to be done every 2 years in California.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Failed Emissions/Smog! | NaeSLaS | 86-95 Trucks & 4Runners | 18 | 02-04-2008 06:36 PM |
| Another failed smog thread | 87_Runner | 86-95 Trucks & 4Runners | 2 | 06-13-2007 11:12 AM |
| Failed SMOG Check. HELP | Bassinfool | 86-95 Trucks & 4Runners | 9 | 09-29-2006 01:37 PM |
| Smog Test Failed - Need Help | junbug | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 03-15-2005 09:49 AM |
| Help with failed smog test. | desertoy | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 09-17-2002 02:40 PM |
