ECT sensor plug
Old May 7, 2012 | 09:49 AM
Peacefrog53's Avatar
ECT sensor plug
Will someone just take a picture of where the wire for the ECT comes from? I put the new motor in my 4runner, (from PO) and noticed that there is no ECT. There is the sender unit for the guage, but no digital sensor on the intake manifold. To add to this I can't even find a plug to plug into the sensor. Where the heck is it supposed to be? I know where the sensor goes, but can't fnd the plug. Is it on the drivers side of the wring harness, or the passenger side? A picture would be more than awesome.
Old May 7, 2012 | 04:36 PM
rworegon's Avatar
What engine/year?
Old May 7, 2012 | 04:45 PM
Yea that might help. It's a 97 4runner with 3.4. 5vzfe. Automatic 2wd.
Old May 7, 2012 | 04:51 PM
rworegon's Avatar
Always does...
Ok, it comes out of the wiring harness right behind the passenger side cam gear....on my 95.5 it is a gray plug. The ECT should be like 4-5" away under the fuel runner cross over.
In the second picture of the first post, it's the second plug back from the passenger cam gear. See it? You can see where the ECT screws into the lower manifold too. The last picture in post 8 shows the senson without the wire pigtail.
http://www.toyota-4runner.org/3rd-ge...-timeline.html
Old May 7, 2012 | 05:07 PM
Ok. I'll pull the plenum off and take a little peek. Thanks man. Much appreciated
Old May 7, 2012 | 05:11 PM
rworegon's Avatar
Should be able to see it without pulling the plenum. Is the ECT sensor in there? If not, the crossover on the fuel rail will need to be pulled (possibly the upper minifold too).
Old May 7, 2012 | 06:03 PM
I'm missing the wiring harness from the little plug to the sensor.
Old May 7, 2012 | 06:22 PM
rworegon's Avatar
That will likely be a dealer only item. IIRC, it's a $6-10 wire. p/n 82219-34020
Old May 7, 2012 | 08:05 PM
Ur friggin awesome. Thank u very much.
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
Lochsa
Aug 2, 2015 02:51 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
bryan34w
Jul 6, 2015 05:53 PM
