E-Locker Mod Trouble Shooting
which safety option are you trying to disable???
I used phongs write up to wire mine, but left both safety options on.
http://www.sonoransteel.com/phong/re...ic_locker.html
i want to be able to use it when i need it instead of 4lo and all its says it to ground the blue/red wire wich i did ? but it dont say anything about it blinking
when you tested it..did you try moving forward/backward to engage the lock or were you stationary? hows your ground connection? i think blinking means its on/trying to engage. not blinking/solid on means locked/engaged...
i tryed goin up a small grassy hill and it just spin one tire so its not working and it dont work in 4lo my spot for the ground must be a bad spot or something its in the same spot as in the writeup
elton, for some reason i remember this referred to the gray wire mod also. i cannot remember which color the wire was but ill go out and check it to make sure.........
only thing i can think of.....
did you remount the box? maybe it needs to be grounded. in the pic, you just have it hanging there.
i just unplugged the connector and left the box in there when i did it.
if you have some long wire, just run it to the battery to make sure it works or dosnt. other than that.....?
it still wont work in 4lo since you re-ground it?
Are you sure it worked before??
Check all your fuses...
So now its back to OEM wiring and still doesnt work?
Just re-read your last post, you need to trick the box not the locker....
