Drivability issues with 37's...
I have searched and haven't found out much. I am about to embark on my 5" suspension lift/3 inch body lift and 37's on the truck. I have 5.29 gears coming. I drive a good deal with the truck city and highway. What will be different about driving now that I am 8 inch's up with 37's??? I also have dual steering stabilizers to install.
Gas Mileage?...get around 23-24 now
handling?..handles ok now
top speed...and how does it do getting there???
I am planning on an intake/header/exhuast in the future to help move these tires better..
Thanks in advance.
Thanks in advance.
I do not have 37's, but my guess is that if you have to ask these questions, you should not be running that much rubber.
Mileage will degrade, so will braking, accelerating and clutch wear if you have a stick.
ok...then...thanks for the help. I think I am going to sell the 37's...buy 33's, and just do the suspension lift. Thanks for the fast response....you think my new idea is better??
Originally Posted by oly884
Much better. That's about the set up I had, and it worked wonders.
you had 33's with a 22RE and 5.29's? how did it do? i will be doing the same in the spring but might just go with 4.88's thanks cody
5.29s might be too steep for 33s, 4.88s would probably be better
37s would should be ok..... mileage will go to hell though, gotta imagine lots more wind resistance, lots more rolling resistance, a couple extra hundred pounds of wieght.....
5.29's are fine for 33's and larger. I run them with 33's and a 3.4
I would not sweat breakage as much as alignment. That is a lot of weight for IFS. I toast an idler every other trip with 33's.
crammit442
7
11-29-2017 12:30 PM
rjtrials
08-06-2015 07:25 PM
FS[SouthEast]: 87 toyota pickup 4x4 22r
Yota.Jay
07-26-2015 05:50 PM
