Doors Wont Lock!
Anyone? There's nothing aftermarket except the stereo, and I'm positive that's hooked up right. I think it may be something with the ignition switch...? Maybe it thinks the key is still in there?
Location: From Honolulu, Hawaii, currently in Beaverton, Oregon.
Body ECU
Had the same problem on mine. Although I could lock mine manually with the key, it just wouldn't lock the rest of the doors.
I was hoping it was a cheaper fix, but I finally broke down and ordered the Body ECU. It's where all the fuses go under the steering wheel. Expensive part at $300-400 but it solved the mystery.
Same thing happened to me in February of this year then all of a sudden the doors would lock again. But only with the door switch. If it goes out again I'll have to replace the body ECU; which I hear is an expensive part.
moonpie
07-31-2015 11:58 PM
