Does toyota dealer sell remanufactured waterpump?
I happened to come across a few seller in ebay who claims that,
"....now in the US the Toyota dealers only sell it remanufactured, not new, and for $124......"
Is this true?... hard to believe but if this is true...
how about toyota of dallas?
I have ordered many parts from tod for many past years. None of the parts seemed remanufactured... (oem stickers with correct numbers have been attached...)
One more question:
Do we buy the "AISIN" waterpump from ebay (the 40~50bucks ones, which are considerably cheaper than dealer price)? I have always used "OEM T-belt, T-stat, Waterpump". I do not at all want to compromise for such critical enginer cooling/timing components. But if the "Aisin" parts from ebay are trulely identical to OEM..... why not?
Thank you
One more question:
Thank you
Aisin makes them for Toyota.
I wouldn't hesitate to use reman'd parts with a Toyota label, but AFAIK the eBayer is ... incorrect. That would be a polite way to put it. Incorrect.
that's true, the 5vzfe is a remanufactured water pump with a -84 at the end, I work at a Toyota Dealer
And yes you can get a Aisin water pump for about 50$ at any auto parts, and it is the same part(without Toyota written), but the aisin auto parts one is a new one...
Boris
Boris
Thanks all for your inputs.
Now, I feel like I am challanged not to order the parts from TOD. I may try non-oem "Stamped" waterpump for the first time in my whole history of car maintenance... should I feel guilty? ^^; it is hard to resist to pay less for newer product compared to reman part... In other words, I can not justify myself to pay more only to get "toyota" stamp (even on non-new part...) Am I on the right track?
Can I also assume that many of the members are also purchasing "Aisin waterpump" than reman toyota one.... Am I right?
a reman pump, alternator, or starter, obtained from a dealer is probably
gonna be better than a new one. all that is retained is the hard metal casing,
(in electrics, the core windings) everything else is new
so, reman OEM doesn't mean 'less quality' one bit.
what does mean less quality, is stuff that doesn't have a toyota sticker on it.
you cannot trust stuff that just 'fits' but is made by someone else.
Aisin makes the water pump along with a lot of other parts like master brake cylinders and what not. In fact, you'd be hard pressed to find any car manufacturer that makes every part of the car. They send the design to Aisin and they make it. So whether it has the Toyota stamp or not, as long as its made by Aisin its the same exact part.
I personally would rather pay less for a new part than the same exact part remanufactured.
To be blunt, that's elitist banter.
umm, no it isn't
parts like rubber seals can be made over 100 ways in 60 different formulations,
a water pump for a toyota of a specific model and type and year, is going to specify a certain type of seal with
specific characteristics.
so roll the dice.....I will go with oem
As mentioned, part for part OEM and the OEM manufacturer sold elsewhere are exactly the same part. No dice involved. Aisin = Aisin, Koyo = Koyo, NSK = NSK, Denso = Denso, and so forth. Toyota label or not. You do have the feel-good advantage of supporting Toyota's sometimes inefficient supply chain however, if you insist on Toyota labeled Aisin parts.
If you are talking AutoZone hydraulics, well, that is a different matter entirely.
Ok!, here are what I "practically" summed up,
=> Ordering from toyotapartsales.com (toyotaofdallas)
OEM Tranny filter
OEM Water pump
OEM Thermostat
OEM Spark plug
OEM Idler pulley
OEM Timing belt
OEM Alternator belt
OEM Ac belt
OEM PS belt
OEM Lower Radiator Hose
OEM Upper Radiator Hose
Total : ~ 360bucks shipped.
=> Ordering from aftermarket vendor (rockauto.com)
ACT(?) Tranny filter
AISIN Water pump
Kuzeh Thermostat
Denso Spark plug
OE replacement(?) Idler pulley
Mitsubishi Timing belt
Bando Alternator belt
Bando Ac belt
Bando PS belt
Goodyear Lower Radiator Hose
OE replacement(?) Upper Radiator Hose
Total : ~ 260bucks shipped.
Considering the manufacture's brand that rockauto is offering, I wouldn't feel that much guilty(?) even if I use such aftermarket parts to my 97 4runner.... (saving $100...). Only concerns are "Kuzeh Thermostat", "ACT Tranny filter (never heard of)" and "OE replacement Idler pulley" (I am not sure what that OE replacement mean.....)
Any other thoughts?
OEM Tranny filter
OEM Water pump
OEM Thermostat
OEM Spark plug
OEM Idler pulley
OEM Timing belt
OEM Alternator belt
OEM Ac belt
OEM PS belt
AISIN Water pump
Kuzeh Thermostat
Denso Spark plug
Bando Ac belt
Bando PS belt
Any other thoughts?
I would go with NGK plugs and OEM t-stat for peace of mind. A crucial component like the t-stat I would only purchase as OEM considering a t-stat has absolutely zero room for error.
jerusry
10-19-2015 05:28 PM
Road Bull
10-10-2015 04:55 PM
