Does the RR locker imply a gear ratio?
Old 11-19-2009, 12:58 PM
rideexileex's Avatar
I've been doing a lot of searching and can't find anything concrete.
Correct me if I'm wrong, but I remember reading somewhere that the elocker factory option implied that the gearing ratio would therefore be lower. Is this true? If so... what is it?
I recently rolled my last 4runner that didn't have this option and am looking at buying a new one (2000 limited AT) with the locker option and want to upgrade from my old 31's to 33's, and adjust the gearing close to the recommended (31" - 33" tires) 4.88 ratio. I'll probably stick with getting the BFG AT's - I do a lot of driving in the snow and these have been great.
Old 11-19-2009, 01:03 PM
Elton's Avatar
mine has 4:10s with the 5spd it still ripps with 285s shoot my friend has a 85 on 35s with 4:10s and a 22re it moves along just fine
b0n3mast3r's Avatar
i suggest you get 1 with out vsc or traction control if you want fatorcy locker
Old 11-19-2009, 01:05 PM
Elton's Avatar
yea i dont think you can
Old 11-19-2009, 01:47 PM
2000 was the last year to offer the factory rear locker - 2001 was when the rear locker along with 5spd died, and were replaced with the center diff lock option and traction control.
Found what I had read before:
http://www.top4runners.com/runhist/3...00_4runner.pdf
2nd page, mid section, right side mentions the locker having a 4.3 gear ratio.
Can anyone else confirm that a rear locker option always automatically implies a 4.3 ratio?
Old 11-19-2009, 01:55 PM
Pikeman's Avatar
The 4Runner with factory locker was available with 4.10 and 4.30 ratios. That is based on the research I have done from here and a few other sites.
Old 11-19-2009, 02:02 PM
elmerfudd_22's Avatar
apparently they also made a 4.56 gear for the 4bangers only?
Old 11-19-2009, 04:18 PM
CYi5's Avatar
If it came with stock 16" alloys and locker you'll have 4.30's.
Old 11-19-2009, 04:21 PM
Elton's Avatar
i think auto's had the 4:30s
Old 11-19-2009, 04:38 PM
crolison's Avatar
Yep, mine came with 4.56's stock from the factory
Old 11-19-2009, 05:05 PM
troyboy162's Avatar
my buddie has 5 speed with 4.30's from the factory
Old 11-19-2009, 05:55 PM
Elton's Avatar
now how do i go finding that out cuase i checked it and it said 4:10s
Old 11-19-2009, 05:59 PM
Red3.slow's Avatar
My 2000 SR5 V6 With auto and the locker has 4.30's
I almost wish I had 4.10's though since I'm mostly highway with this one, not near as much city or off road as I did with the 95 It had 4.56's from the factor
Old 11-19-2009, 06:09 PM
b0n3mast3r's Avatar
how do i know what gear ratio i have 98 limited 4x4 factory rear locker ?
Old 11-19-2009, 06:11 PM
High Water Drifter's Avatar
go to this link to find your gear ratio....http://www.sonoransteel.com/Toyota_axle_codes.html
Old 11-19-2009, 06:16 PM
Elton's Avatar
thats where i went
Old 11-19-2009, 06:20 PM
b0n3mast3r's Avatar
cool thanks
Old 11-19-2009, 06:25 PM
b0n3mast3r's Avatar
so i got the 4.10 but there is a 4.30 option so what now?
Old 11-19-2009, 06:27 PM
b0n3mast3r's Avatar
o never mind i got the 4.30 and what the diffrent between the 4.30 and 4.10
Old 11-19-2009, 06:58 PM
02SE's Avatar
Unless it's equipped with 4.10's like my '97, V6, 5speed, 16" alloy wheels, W/rear diff lock.
Quick Reply: Does the RR locker imply a gear ratio?
