Disable rear heat - 3rd gen
Our 97 4runner has a hole in one of the hard lines feeding the rear heater core. Seems to be a common problem from what I've seen on the board. Can someone tell me what the steps are to bypass the rear heater?
Also has anyone replaced one of these hard lines? Was it very difficult? I'm guessing its probably not a cheap part from the dealer.
The line nearest the middle of the engine bay. Thanks for the offer, but I don't think I am feeling like a drive to Washington tomorrow.
If you can get to the hard line cut out the leaking bit and put a piece of rubber heater hose in the gap, clamped at both ends. There's not a lot of pressure in the heater system so it should hold.
06-01-2021 01:51 PM
the1998sr5
15
07-14-2020 08:35 PM
jerusry
10-19-2015 05:28 PM
tpd143
07-07-2015 09:06 AM
