YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 02-27-2006, 08:38 AM   #1 (permalink)
Personal Sales Rating: (0)
OutdoorLiving's Avatar
Exclamation Differential oil leaking from the breather. How much is too much?
Hello all.
It always seems the first post in a new forum is a cry for help.
So that being said, I have a 1998 4WD 5SPD 4 Runner that is experiencing some minor front differential concerns.
A little history:
~4wks ago I had the oil in both differentials flushed.
Friday night I was stuck in a couple hours of stop-n-go (and long idle) traffic.
This morning I noticed the smell if differential fluid when I pulled into the driveway. I climbed under the truck and noticed that there was a "fair" bit along the front of the transfer case and that side of the engine. Come to find out that it appears that 100% of it came through the breather from the front differential.
No obvious change in gas mileage, strange noises, shifting, etc.
Exactly how much as blown out, I have no idea. Just enough to collect in those areas, but not enough to cause any puddles. I plan on cleaning the truck off and giving it a look over to see if it's still coming out.
Is there any way to tell how much has leaked out?
And how concerned should I be?
OutdoorLiving is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 02-27-2006, 08:46 AM   #2 (permalink)
Lone4runner's Avatar
lol this is exactly what i asked yesterday welcome to the board. btw
__________________
ED
1999 4Rnr Ltd, Deckplate mod, R Diff Breather. ISR, Hella 500, Cobra 18WXSTII, Denso IR plugs, Magellan GPS, Sirius, 285/75R17 Firestone Destination MT, Wheelers Type B 16x8 Black rims, K&N Filter, TJM T17 Bumper w SS Bumper brackets w/ shackle hangers, 1st gen Roll cage, SS Extended pan hard bar, SS Diff Drop, Stainless Steel Goodridge Brake Lines, Hellas 500, 2"BL, Budbuilt Skidplates, SAWS, OME 891, OME N86,FF sliders, 15 lb Co2 Ultimate air, Ammo tank(for storage:), Optima Red top
Lone4runner is offline
Old 02-27-2006, 08:49 AM   #3 (permalink)
Threadstarter [OP]
Maybe I should just watch your thread. I haven't had time to look through new posts in the past 4-5 days.
Old 02-27-2006, 08:53 AM   #4 (permalink)
PirateFins's Avatar
Send a message via AIM to PirateFins Send a message via Yahoo to PirateFins
Well I would be concerned at any fluid that is leaking out. The shop could have over filled it and that breather is doing its job and letting the expanded fluid out, or something could really be wrong. The best way to check your level is to park on flat ground, open the fill plug and have a look/feel. The fluid should be level with the bottom of the fill hole. Or if you want don't clean it and take it back to the shop that did the flush/fill and have them look at it. Since it didn't leak before the flush, I would bet they put to much in, but be safe and check it.
__________________
Brad
Work is for those who don't know how to plunder!!
Quote:
Originally Posted by habanero View Post
I'd experience an O so big it'd show up on the richter scale.
92x-cab dlx 4x4 22RE, Pacesetter header, everything else is so stock it's not funny, cause I don't have the money!
04 F150 FX4 SuperCrew
PirateFins is offline
Old 02-27-2006, 12:29 PM   #5 (permalink)
Quote:
i honestly dont care whos thread lol but as long as we get the answers we are looking for. I checkd mine again today and maybe its the cold but it shimmers of possible gear oil left over from 2 days ago when i cleaned my wires from the breather all the way attached to my steering rack. Since it doesnt look red and smells like gear oil more than power steering fluid. I am hopeing.
http://www.yotatech.com/showthread.p...+breather+leak
these kinda make me feel better. but good luck with yours
__________________
ED
Old 02-27-2006, 01:17 PM   #6 (permalink)
Threadstarter [OP]
More observations:
Before I left work this afternoon, I wrapped a piece of paper towl around the edge of the breather tube to give me an idea as to if any more fluid would escape while I drove home. 19mi home, with most of that being interstate didn't yield any fluid leaking out of the breather.
Undaunted, I got ballsy enough to engage 4WD and drive around the nighborhood for a mile or two and it didn't produce any more leakage.
The oil appears as if it were regular engine oil, but is thicker and has that differential oil smell. Unfortunately, I don't have any level ground at my place to check it out. I believe I'll change clothes, take it down to the wash and give it a good blast to remove the current oil and watch it closely afterwards.
I've resolved it could be one of three things:
1. It was overfilled.
2. Maybe it's not the right kind of oil?
3. There is water in the front differential?
I'm hoping it's #1. Stay tuned and I suppose we'll find out.
Old 02-28-2006, 03:38 PM   #7 (permalink)
after today i have confirmed that i am leaking from the dust boot on the control valve. question is i would need to buy some new tools to do that seal on the inside i think. wouldnt it be worth it more if i just bought a remanufactured rack at $290 instead of $85 on the seals and tools ? I guess the oil coming from the front was gear oil that came out of my breather which was clogged. what do you guys think?
__________________
ED
Old 02-28-2006, 04:03 PM   #8 (permalink)
Threadstarter [OP]
And an update on mine...
Washed my truck yesterday evening. The smell lingers (gag) but still no signs of continued leakage. Won't get a chance to crack it until this weekend.
Old 03-06-2006, 03:21 AM   #9 (permalink)
Threadstarter [OP]
Another update...
So for the past couple of days there hasn't been much of anything happening with the front differential. However, the past couple of days the girlfriend and I have been doing some house shopping and I noticed the smell of diff fluid again. Crawled under the truck at a friends house and I found more fluid. Not as much as the first time, but it's in the same place.
Either Toyota SERIOUSLY overfilled the front differential, or I've got other plans. If the rain knocks off today I'll crawl back under it and see if I can figure out what the hell the problem is.
__________________
1998 SR5 4WD 3.4l V6 5SPD
Dealer Options: 4.10:1 RR Diff Lock; Brush Guard w/ Hella driving lights [removed]
Mods: Thule Roof Rack w/ Canoe Gunwhales; Silverstars; Bridgestone Revo 265/75/16s; Maglite mod; Deckplate mod; Stickers!
Wishlist: TJM T-15; Custom rear bumper; 2" suspension lift; Satoshi mod; Gray-wire; Sliders; Full length skid plate; etc
Quote:
Originally Posted by SC4Runner
Wow, thats gayer than me!!
Old 03-09-2006, 02:16 PM   #10 (permalink)
Threadstarter [OP]
Another update...
Removed the skid plate and crawled up under the truck to determine what was going on with the front differential. Determined that the leak is actually quite small, but at the elbow coming out of the front differential. It's hard to tell, but there might be a crack in the hose at that point.
Unfortunately, I didn't have an allen wrench of the correct size to open up the front differential to check to see if it was overfilled or not. It'll have to wait until I can pick one up and crawl back under there and check...
__________________
Old 03-17-2006, 03:42 AM   #11 (permalink)
Threadstarter [OP]
Yet another update...
I finally made an opportunity to look at it closer. Here is what I know:
1. The front differential is not overheating. After driving it 30mi, I pulled the skid plate off and could immediately work on the differential without burning my hand, etc. Of course, the oil pan is hot!
2. The front differential is not overfilled. I removed the fill plug and wasn't greeted by oil in the face. I inserted a finger (kinky) into the hole and the oil is just level with the plug.
3. There isn't any water in the differential. Or, I'm assuming not, since I would think water would actually float on 90wt oil.
4. The fluid is still very much in good shape -- I had the front differential flushed (NO PROBLEMS PRIOR) < 3k ago.
5. An unknown (enough to smell when outside the truck and the engine is hot) amount of differential fluid continues to leak out of the breather extension semi-regularly. Some days I can smell (and see) it. Others I can't. No change in driving patterns or distances.
PLEASE HELP!
I'm absolutely stumped and don't particularly want to grenade my front end.
The only thing left I think I can do is completely flush the oil in it and replace with what I KNOW to be the correct oil. I don't know how many different types of differential oil there are -- but it's definately gear oil (smells it). Could the wrong weight oil cause these problems?
__________________
Old 03-17-2006, 02:41 PM   #12 (permalink)
Threadstarter [OP]
<bumpidy>
__________________
Old 03-18-2006, 09:45 AM   #13 (permalink)
RIPPER's Avatar
I have a similar problem with my rear. I have leakage through my ARB compressor. Yea thats right. My extended breather was not working causing the backup of pressure which sent fluid through the air line up to the compressor. I called ARB and evendently they have had numerous calls about this. Their solution is to remove the extended breather and run it "open". This worked for a little bit then I noticed that the line was cracked right at the housing fitting but no fluid was comming out which tells me that my fitting is clogged causing the fluid to come out of the compressor. Once I get my household goods I will fix it. I just need to make sure that my diff level is good. Hope this helps!!
__________________
'96 Runner Deck plate mod, Downey adjustable lift 3", 315/75/16 GeoLander AT+II, PP front spoiler, PIIA Fog lights, Custom Panhard rod, Extended Rear Break line, Optima Redtop, 4.88's, ARB lcokers F+R, Addco Swaybars, Lars Quick Disconnects F+R, Electric Fan Mod, RB 3" Body Lift, SS Upper A arms..........
RIPPER is offline
Old 02-08-2007, 01:07 PM   #14 (permalink)
Subscribing as I just noticed my '99 is leaking from the front breather as well.
TimZ is offline
Old 02-08-2007, 02:30 PM   #15 (permalink)
me too, i will def. keep an eye on this thread
__________________
Joe
1997 4runner limited
SS #1 lift, 1" 4crawler bl, Black Chrome fzj80 wheels, 295-75r16 Nitto Terra Grappler, Hella 500 driving lights, deckplate, satoshi grille, extended rear diff breather, and a bunch of other junk.
rocktown is offline
Old 02-08-2007, 02:57 PM   #16 (permalink)
ADH8796's Avatar
Send a message via AIM to ADH8796
I didn't take the time to read anything except for the very first post. If your diff breather is leaking out gear oil than it was over filled. There is a plug in your front IFS similar to the plug in your rear diff that you can take off to fill your diff. Take both of those plugs out and and if fluid drains out than that's alright just let it drain until it stops. Your diffs should only be filled up to those plugs no higher other wise it comes out of the breather. Hope that made since.
ADH8796 is offline
Old 02-08-2007, 03:06 PM   #17 (permalink)
Quote:
that's what i have suspected in my case all along, however its been just TOO COLD to work on the runner outside...I changed my oil last week and that was a baddd mistake
__________________
Joe
rocktown is offline
Old 02-09-2007, 12:42 PM   #18 (permalink)
ADH8796's Avatar
Cool well good luck with it. It shouldn't really hurt anything.
ADH8796 is offline
Old 02-12-2007, 02:40 PM   #19 (permalink)
Thumbs down leaky front diff breather hose
I have a 2001 tacoma and the same thing is happening, leaking out the breather hose. I had to add some gear oil because it was starting to make noise. The noise dissapeared when I added oil but it keeps leaking out.
tacoma8902 is offline
Old 02-13-2007, 04:56 AM   #20 (permalink)
I'm having the same problem and I confirmed the oil is leaking from the breather by wraping a paper towel around the check valve also. It's definitely diff oil and everthing on mine is working normal. I'm not overfilled since I did my oil change about 2 years ago and it did not keak until recently.
Regardless, I dropped my skid and check everthing again and it's fine except for the leak.
Here is a tread I started earlier:
http://www.yotatech.com/search.php?searchid=2688761
__________________
99 4Runner SR5 4X4 Stock
87 Extra Cab DLX 2WD (Sold after 21 years)
2007 Tacoma Access Cab 4cyl 5 spd 4X2
DOT3 is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
4runner, 95, breather, change, comming, differential, f150, fluid, front, full, gear, leaking, oil, overfilled, signs, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Front Breather Leaking oil Lone4runner 95.5-2004 Tacomas & 96-2002 4Runners 9 02-27-2010 09:49 AM
Rear Differential Leaking Oil and Making Grinding Noise???? ivanr 95.5-2004 Tacomas & 96-2002 4Runners 3 04-26-2007 11:25 AM
differential breather Just Learning General Vehicle Related Topics (Non Year Related) 6 10-31-2006 06:07 PM
For Those Who Are Going To Do The Differential Breather Mod.... fireteacher 95.5-2004 Tacomas & 96-2002 4Runners 11 04-17-2006 05:56 AM
leaking differential ....breather is fine spacewrangler 95.5-2004 Tacomas & 96-2002 4Runners 4 09-07-2005 11:28 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
