Diff. Breather Question
Old 01-12-2004, 03:29 PM
GRNTACO's Avatar
Do you need to use Teflon tape or thread compound or anything like that for the piece that goes into the differential?
Old 01-12-2004, 03:39 PM
waskillywabbit's Avatar
Re: Diff. Breather Question
I don't think so as I haven't seen it listed on any of the write-ups I've read, plus some of it might get off into the diff by accident while screwing it in with teflon tape on it.
My pennies!
Old 01-12-2004, 03:43 PM
GRNTACO's Avatar
Thanks waskillywabbit, I haven't seen it in any write-ups either so I am not going to use anything.
Old 01-12-2004, 03:48 PM
Bob_98SR5's Avatar
GRN,
I believe most people do use teflon tape. At least that's what I researched before I did mine. http://www.4runners.org/articles/typerdiff
Bob
Old 01-12-2004, 03:50 PM
GRNTACO's Avatar
Originally posted by Bob_98SR5
GRN,
Bob
Thanks Bob, that is a good write up. So now I have heard with out and with
Old 01-12-2004, 03:53 PM
WATRD
Bob and I like to respectfully disagree on lots of things these days it seems...
http://www.wattora.com/mods/diffbreather/
But this is the site I used to install my rear diff and I don't recall any tape, but I don't think it makes a big difference since the fitting screws in there pretty far and doesn't have tape on it when it comes out.
:guitar
Old 01-12-2004, 04:13 PM
WATRD's Avatar
I don't use tape. It's air tight without it. Have you ever seen the mess that teflon tape leaves in the threads when you take something apart? If you ever have to remove the breather, all those fragments are going to be in the diff
Old 01-12-2004, 04:15 PM
jalaber's Avatar
I used teflon tape also. Think it is in my write up as well.
Old 01-12-2004, 09:23 PM
Guest
jruz's Avatar
Teflon tape = plumbers gimmick
The inventor has probably long since retired (with much money)...but did he ever prove his case? Probably not.
Jim
Old 01-13-2004, 02:54 AM
Cmar's Avatar
I wonder if a few little bits of teflon tape in the diff will cause any problems....
Heavy duty gears verses tape bits..........
No contest really
Old 01-13-2004, 04:31 AM
FirstToy's Avatar
Teflon tape can cause leaks in some threads you lock down. Toyota didn't use any and it really isn't necessary for that location.
I don't think it matters if teflon tape got into the diff since teflon is itself a lubricant.
Old 01-13-2004, 04:41 AM
Jonathan's Avatar
I didn't use it. Doesn't seem to me that it is needed. The plug locks down pretty tight without it.
Old 01-13-2004, 05:08 AM
CTB
CTB's Avatar
Another vote for not having used tape.
Jonathan, ever get those pics with your lights on?!?!
Old 01-13-2004, 06:53 AM
Arnold's Avatar
Used teflon tape on mine, just enough to cover the last couple threads towards the barbed ends. Sometimes people go a little overboard w/ using the stuff.
Old 01-13-2004, 06:54 AM
GRNTACO's Avatar
Well it's unanimous but there was some good points. I am not going to use anything on the threads.
Thanks for all the input
Old 01-13-2004, 06:58 AM
GRNTACO's Avatar
Now I'm wondering what is the temp rating on Teflon tape. I have put a IR gun on my diff. to see how hot it gets and after driving 40 mile it was 150*F.
Old 01-13-2004, 07:10 AM
bamachem's Avatar
If it worries you that much, put it in without tape, then put a bead of silicone around the base where it goes into the threaded hole. That would keep anything out that the threads might allow to pass.
just my $0.02
Old 01-13-2004, 08:01 AM
Robinhood150's Avatar
Don't worry about that, I've used teflon coated wires in very high temperature ovens. Plus...they use teflon on frying pans!
Old 01-13-2004, 08:12 AM
SkyRat's Avatar
I have always wondered how they get the Teflon to stick to the pan, since it is so slippery and all....
Old 01-17-2004, 06:16 PM
KevyWevy's Avatar
where did all of you 2nd gen guys run the end of your breathers? and also is it bad to leave the end of the breather tube open?
Quick Reply: Diff. Breather Question
