| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
diff breather extension
__________________
-chad- 2000 4runner SR5 4wd 5sp | 1" lift pp coils | ARB bumper | 265/75/16 MT's on american racing wheels | detroit locker | deckplate, MIT and AMSOIL | magnaflow exhaust | Lars's discos | extended diff breather | yakima roof rack | |
#2 (permalink) |
No need for it to be vertical, the stock breather fitting must be vertical since it relies on gravity to close the cap off to seal the axle. With a raised breather, you want to use an open filter of some sort on the end, orientation is not an issue, *but* make darn sure the vent lines runs up all the way to the end, you don't want any dips in the line. I did this on mine (tried running the rear line to the front) and found that oil mist pooled in the low spots in the line. Come winter and cold weather, 90W gear oil turns thick, enough to plug the line, pressure builds in the axle from heating and pushes oil out past the seals.
I run my rear vent into the space behind the taillight: http://www.4crawler.com/4x4/CheapTri...html#Breathers
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
I mounted mine under the hood. Pretty easy to route the hose... Just took a bit more.
__________________
-Mikey- 1993 4Runner ~ TG HD/RUF front | All Pro rear | 37" Krawlers | Marlin UM06s | 12" King 2.5s | 2" air bumps | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | 4xInnovations cage | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | LED rock lights | PIAA superwhites | stereo Polygoats 4-Wheel Drive Club Poly Performance |
#4 (permalink) |
where did ya get those filters and what type are they i tried looking for some and didnt have much luck i ran mine front by the battery with opening facing rear and the rear up thru whats left of my bed to just behind the tail light facing rearwards i did leave some slack in the lines for flexing
__________________
80 toyota flatbed 22r ,headman header,weber 32/36,8" lift,36*12.50*15 swampers,4.88, aussie locker in front yukon spool in rear,co2,full cage |
#5 (permalink) |
Mine is asmall K&N filterm probably a valve cover breather or something like that. A small VW air cooled fuel filter works well, or any of the small filters at the local auto parts stores will work. The filter is mainly there to keep small critters (spiders and other bugs) from crawling down the hose and plugging it up.
__________________
#6 (permalink) |
Mine are APCs from WalMart. $8 or so a piece, I think...
__________________
#7 (permalink) |
hmm, from all of the write ups I've seen for extending the breathers, they still use a breather similar to the factory one.
example: http://www.yotatech.com/~corey/tech/...r/breather.htm so would you guys recommend a small air filter over this breather?? and, 4crawler, I take it this breather would also have to be in an upright position since it's similar to the factory one?? thanks again everyone
__________________
#8 (permalink) |
Read my page for a full explanantion, but one of the reasons for extending the breather tube is to get rid of the stock breather, as it is part of the problem. Why? Stop in deep water with a hot axle full of hot air and guess what happens? The axle and air inside it cools. Cool air has a lower pressure (i.e. partial vacuum) and ideally you want to be able to pull outside air in via the breather tube to equalize the pressure inside the axle. Why? Because there is a chance of differential pressure sucking water in past the axle and pinion seals into the partial vacuum inside the axle. Stock breather is designed to close off and seal the vent when you stop, in case you are in water. If it remained open, water would pour in the open hole. But its the very design of the stock breather that can lead to the secondary problem of the partial vacuum. Normally when you are moving, the cap on the stock breather jiggles and allows air to move in and out, but stopped it seals off. So if you want to use a stock breather on the end of the tube, mount it upside down in order to let the cap hang free and not seal. A filter is a better option as it'll also help to keep out dirt and also filter the oil mist out of the escaping air.
__________________
#9 (permalink) | |
Quote:
__________________
#10 (permalink) | |
Quote:
__________________
#11 (permalink) | |
Quote:
Thanks for the help everyone!!
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| First OME flex shots (with new breather extension hose) | MillerPKA | 95.5-2004 Tacomas & 96-2002 4Runners | 18 | 05-16-2007 12:22 AM |
| Diff Breather Extension Mod | Gangus2006 | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 11-01-2005 10:52 AM |
| Rear Diff Breather Extension | Darx | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 07-24-2004 04:33 PM |
| Rear diff breather extension complete | TDiddy | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 04-27-2003 02:00 PM |
| Breather Extension Questions | az4x4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 01-24-2003 08:19 PM |
