Dash Clock Problems
Old 07-08-2007, 08:29 AM
DOT3's Avatar
Dash Clock Problems
Do all year 4runners have the problem with the digital clocks?
Has anyone determined if there is a fix for the problem?
Mine is in the intermitten stage but is still working most of the time.
Old 07-08-2007, 08:53 AM
Farmerunner's Avatar
It helps if you tell us what the problem is.
My clock works fine and the only problem is I am always running late.
Old 07-08-2007, 09:13 AM
MATT0404's Avatar
Mine is out completely. I'd be interested in seeing if anyone has a fix for this.
Old 07-08-2007, 01:07 PM
pattycakes77's Avatar
yeah, mine goes out but if i thump it or tap on it, it comes back but then fades away again at some point. i don't know what the problem is but if they could be fixed that would be great. i think it's funny that if you look on ebay people are selling used dash clocks for $75 on up and those clocks are probably going to do that same thing in a short time. i'm thinking of just getting a nice gauge that has a clock, outside temp, and compass all in one and bypass the stock clock. that gauge that i'm talking about is about $300 though but it's trick!
Old 07-08-2007, 01:50 PM
MillerPKA's Avatar
Mine is a 97 with the original clock and i've never had a problem. Can't believe replacements are that expensive though...ridiculous!
Old 07-08-2007, 02:22 PM
crolison's Avatar
Mine is almost totally out, 95 percent of the time doesnt work. Other 5% i have to tap it or hit the dash for it to work, i dont worry about it.
Old 07-08-2007, 02:28 PM
DOT3's Avatar
Do any of you guys with 2000 or newer models have problems?
Old 07-10-2007, 01:10 PM
Prospector's Avatar
Selling Mine
I am going to have my vent bezel up on ebay soon and it has the working clock in it. It will probably go for 20 bucks or so. I will let you know when it's up.
Old 07-10-2007, 01:18 PM
eric-the-red's Avatar
No problems in my 2001
Old 07-10-2007, 01:20 PM
alotawatts's Avatar
2001 -
Another 2001 here - No problems ....yet
Old 07-10-2007, 02:57 PM
aviator's Avatar
No probs with my 94 or the 87 before it...
Old 07-10-2007, 03:56 PM
Watrout88's Avatar
I have a 95.5 and it is always going out. I tap on it and it will come on for little while, it's worthless. Who has a fix?
Old 07-10-2007, 05:08 PM
aviator31's Avatar
99 here, it doesn't work anymore. The tapping thing worked for a little while, but nothing makes it work now.
Old 07-11-2007, 04:33 AM
fnrunner314's Avatar
oh yea on my 2000 the clock has been out since I bought it. The PO said it went out on him about 3 months after he bought it in 03.
Old 07-11-2007, 07:01 AM
Enough with the negative waves
Old 07-11-2007, 07:09 AM
Elton's Avatar
mines been broke for years along with the power antenna
Old 07-11-2007, 11:12 AM
Wife's 4runner's Avatar
mine is toast. Stereo tech confirmed it was plugged in. Oh well..
Old 07-11-2007, 12:42 PM
Henhouse1's Avatar
If you have done any "behind the dash" work, the clock plug is very vulnerable to being inadvertently loosened or unplugged completely. There is also another "faux" socket where you can accidently plug it back in and it won't word at all.
Pry out the center dash panel and check the clock plug for security. Might work for you. It did for me on my '99.
Stan Henley
Old 07-11-2007, 12:47 PM
Geographeen's Avatar
I have a 2000 and my clock has been completely functional. "Knock on Wood." I have, however had some of my panel lights go out once or twice in that immediate area. (ie rear window button, temp controls, etc) Those are all cheap, easy fixes though, compared to the digital clock.
Old 05-04-2008, 02:48 PM
Flojules's Avatar
Digital Clock Problems
Thanks Henhouse 1 for some useful info on fixing the digital clock. I have a '99 and it goes in and out. Tapping really hard helps sometimes. I've tried checking the plug connection and that isn't it. Does anyone know what causes it to go in and out? Any other fix ideas? I guess they just go.
Quick Reply: Dash Clock Problems
