Cupholder Fix!
Old 08-24-2009, 02:53 PM
fornesto's Avatar
Cupholder Fix!
I think I may have solved the cupholder dilema that has cursed me for years. I will post pics when I get home. Here's the summary. My cig lighter broke. Actually, the plastic retainer parts broke. I relocated it to the passenger side of the center dash part, right next to the passenger's left leg. There was a write-up on this on another site. I then had the hole left in the dash where the old cig. lighter was. I bought a gambrel-style cupholder from the local West Marine store. These are the kind that swivel from a mount to avoid spills on a boat. The mount is designed to accept two wood screws. Instead, I bought a $.38 wall anchor - the kind that has the spring open V that opens inside the wall and you screw it in tight. I used a 3/8" x 2" screw/anchor setup. I put the screw throught the cupholder mount, folded the anchor part and pushed it into the 3/4" hole left by the Cig. Lighter. It sprung open inside and I sucked it in tight against the back of the dash by turning the screw. The new cupholder sits about 1/2" above the flat horizontal black panel surface near the 4wd shifter. It came with a can-cozy insert, which I may or may not use. The good news is that it holds a Super Big Gulp size cup, it doesn't swing very much, I didn't have to put holes in my dash in case it doesn't work out, it can also hold a mug because it has the handle cut-out, it is located low so it shouldn't fly all over like the stock unit...it is perfect.
Old 08-24-2009, 02:57 PM
v6854runner's Avatar
wow sounds like you did a good job putting in that cup holder
Old 08-24-2009, 03:02 PM
fornesto's Avatar
It's the little things...
Old 08-24-2009, 03:48 PM
Tubbyfatty's Avatar
Check this out haha.
http://4runners.org/writeups/cupholder/index.html
Old 08-25-2009, 11:49 AM
fornesto's Avatar
Originally Posted by Tubbyfatty
Thanks. I've seen that. It's just a lot more complicated than I wanted to do.
Old 08-25-2009, 11:53 AM
bgmac's Avatar
Good god...that looks like a pain in the ass!
Old 08-25-2009, 11:58 AM
X-AWDriver's Avatar
Having a pop spill from the high part of the dash i a pain in the ass to deal with and makes the cupholder mod a must do especially if you off road regularly.
I had a '97 sold it and bought a '99 cause I was too lazy to do the mod..............
...........j/k the '99 just had so much more including a rear locker but the '99's mid gen upgrades made it sweeter and I got the scoop.
Old 08-25-2009, 01:40 PM
fornesto's Avatar
I remember it like it was yesterday. A fresh 44 oz. Dr Pepper with the tapered cup (designed to fit in a can-sized cupholder) riding high in my cupholder in my new 4Runner. Turning the corner out of the Chevron parking lot and "snap". AAaaaawwwww shhhhhhhiiiiiiiiii******* The whole thing fell and exploded on my knee.
Yup....I got (had) cupholder issues.
Old 08-25-2009, 01:49 PM
el-guapin's Avatar
You definitely have to post pics!
Old 08-27-2009, 07:20 AM
fornesto's Avatar
Here's the finished product. So far, it still works.
Old 08-27-2009, 07:26 AM
ShrimpMan's Avatar
Looks like it works better than the factory cup holders! With all the time spent, you could have done the center console swap... Either way, looks good!
Old 08-27-2009, 07:30 AM
fornesto's Avatar
Total expense, including relocating cig. lighter = $25
Total time = less than 1 hr.
Old 08-27-2009, 07:46 AM
okie81's Avatar
Can it still hold a drink in 4-Lo?
Old 08-27-2009, 09:16 AM
fornesto's Avatar
Yup, I checked. The cupholder can also slide out of the mount if you really want the space.
crammit442
7
11-29-2017 12:30 PM
Peevedkitten
11
08-31-2015 06:57 PM
hollypots
North Carolina
13
08-31-2015 04:08 PM
izzmee
08-17-2015 10:20 AM
lectric80
08-11-2015 12:02 AM
Quick Reply: Cupholder Fix!
