Cruise Control Issues
Old Apr 29, 2006 | 06:19 PM
DeckerT4R's Avatar
My cruise control is not working. When i pressed the button on the side to turn on the CC system the light on the dash would kick on but when i pressed down it would not engage?????
I was told to check the switch under the clutch pedal, they said that they stick. The button on the switch worked fine though. I already checked the fuse of course. I have tried many times and different ways to engage the CC, holding the button a long time, a short time, and so on. Is there any way to check the switch under the clutch to see if its bad or do i just have to buy a new one? Or do you not think it is the switch at all? If not what is it? Thanks for any sugg. you might have.
Ben
98' SR5 4runner, 4x4, 5 speed, bone stock.
Old Apr 30, 2006 | 02:53 PM
are you using the CC stalk correctly?
Press the button on the end to engage the CC system (light up CC in dash)
Flick CC stalk down and hold for a second to set speed, pull the stalk towards you to stop CC, push stalk up to reactivate at previous speed.
Is this what you are doing?
I don't think (but I don't know for sure ) the clutch pedal switch has anything to do with cruise control
Old Apr 30, 2006 | 06:26 PM
DeckerT4R's Avatar
Yes i am using it correctly. A guy at t4r.org told me about the switch.
Any ideas?
Old May 1, 2006 | 08:21 AM
sorry but no other ideas. Maybe the CC stalk has issues.
Old Jun 26, 2006 | 04:36 AM
gregbreakseverything's Avatar
Hey deckerT4R, did you ever get your cruise control working? I am having the same problem with my 99sr5 5speed.
Old Jun 27, 2006 | 11:09 AM
ilikesoup's Avatar
There's a sensor on the top side of the clutch pedel. If that is not fully pressed in, then the cruise will never engage. I had this exact same problem. First check that out. It's a simple adjustment. and YES the clutch pedel does have to do with cruise engaging.
Old Jun 27, 2006 | 11:31 AM
I got my head under the dash and watched that switch press and depress. Is there an easy point where i could measure to see if the switch is actually opening and closing?
Old Jun 27, 2006 | 01:44 PM
nermalgod's Avatar
I had the same problem with my 2000 from the day I bought it only the previous owner rewired the clutch switch so it was cut out of the loop. What I found to be my problem was the cruise control box itself. Pop your hood and find the cable coming off of the throttle that runs to your cruise control. Mine was loose so even though the cruise was on and functioning, it couldn't operate the throttle. There is a barrel adjuster on that cable that will take slack out of the system. Check for slack and tighten the cable. That might be your problem area.
nermal
shisha1999
Sep 21, 2015 08:22 PM
coryc85
Sep 9, 2015 06:24 AM
kirkrunner
Jul 27, 2015 07:59 PM
ksmudrunner99
Jul 21, 2015 05:33 AM
voiddweller
Jul 15, 2015 03:56 PM
