convert non-ADD front diff to ADD?
Old 11-12-2006, 08:13 AM
Hornito's Avatar
Is is possible to remove the passenger side cv axle tube from a manual front differential and install the ADD components? The bolt patterns are identical-I just dont know if an ADD stub will fit into a non-ADD differential and still enable 4wd).
Thanks!
Hornito
Old 11-12-2006, 04:20 PM
BruceTS's Avatar
yes it's a direct swap, many have taken off the ADD system when going to manual hubs. If you do the swap you'll need the two vaccum relays and related wiring to make it function properly.
jerusry
10-19-2015 05:28 PM
Daneums
08-20-2015 05:36 AM
scottyg486
07-19-2015 05:34 PM
TokyoD23
07-12-2015 06:01 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: convert non-ADD front diff to ADD?
